Question about Sony FD Trinitron WEGA KV-27FS200 27" TV
Picture keeps turning off with volume still on.
When turning on my tv the picture and sound both work. After a minute the picture starts going from black to on and eventually to all black. The volume still works the whole time. When the picture is off the standby light keeps blinking.
    Scholar:
  • 168 Answers
You have a problem with one of the following circuits: video amplifier, ABL (automatic brightness limiting) circuit, crt circuit or in horizontal deflection and high voltage circuits. probably a leaky component that when it get warm it it looses its function or maybe a cold solder. but if u do not know these stuffs better have it check by a qualified service technician.
Posted on Jan 16, 2007
SOURCE:
Dx-ldvd22-10a does not power up what part do you think broke
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you saveicon1.png any picture settings such as brightness or contrast.
To get the TVicon1.png out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with "Dynamic Mode" shown on the screen. At this point the picture parameters can be changed and saved.
If this method doesn't work for your TV there is an alternate method that might.
From the buttons on the front of the TV (not the remote):
1) Press the Volume + (increase volume) button
2) Whilst the volume button is pressed, press and keep pressed the menu button
3) Let go of the volume button and keep the menu button pressed for 5 seconds
4) After this time the screen should go blank and "Dynamic" will appear at the bottom of the screen.
from
http://www.fixya.com/support/t399140-samsung_le46f8_picture_setting
Jul 27, 2013 | Televison & Video
Volume up then pic gone
You've got a bad solder connection,or broken foil line,s on the pcb (printed circuit board1.gif).Narrow it down by pressing in different places,or use plastic or rubber tip.If not,then you got a shorted load on this fuse and diode.do you have a schematic,whats at the end's of this circuit.D represents a <Diode> not a transistor.
Jan 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Only get please wait after turning on tv
Unplug the set and a box if used--wait for several minutes and plug both back to see if they will reboot.
Apr 08, 2012 | Televison & Video
I have a Verizon FIOS DVR connected to the Samsung receiver. After watching TV for a period of about 30 minutes or so I start to get a delay in the volume coming out of the speakers compared to the picture...
common problem, trouble is that the receiver cant keep up with the dvr box. try this, dont use audio from your dvr into your reciever, take the audio out from the tv, and go into the receiver, now the sound is after the picture and should catch up with itself.
Mar 20, 2011 | Samsung HTC6930W Theater System with...
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
No picture on 50PFP533D
http://www.hdtv-source.com/reviews/B000NV9IYK_1.html#reviews
Please read these reviews, I think you maybe having similar issues.
Jul 08, 2008 | Philips Televison & Video
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Sony FD Trinitron WEGA KV-27FS200 27" TV Logo
204 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
