Question about Cameras
Fe-210 digital camera the plastic plate which holds the memory card and batteries chipped and the top lid will not hold can i replace it and how?
  • 477 Answers
Yes you can call olympus parts department. and they can get you the parts you need. go to there web page for more help.
Posted on Nov 26, 2008
Why does my Olympus FE-210 says ' Card full' on the screen ?
Usually because the memory card in the camera is full and cannot record any more photos. You have to insert a new memory card, or delete some photos from the current inserted card.
Jul 12, 2014 | Olympus FE-210 Digital Camera
Lens wont go in power button wont lite or come on and screen display nothing what is happen to my fe 210 olympus camera
I have the same camera! But my display is broken. :( But it still works. Try plugging in the external video cable to see if you can see the display on your TV.
Make sure the battery is fully charged. If the battery is no longer holding a charge, replace it or use the appropriate AC adapter to power the camera.
Also, remove the memory card if you are using one in you camera.
After you put a freshly charged battery in or plug in the AC adapter, press and hold the power button for at least 3 full seconds. The lens should extend fully. If it doesn't, press the playback [>] button on the back (this should make the lens retract). Then press the power button to shut the camera off. Press the power button again to power it back up and the lens should extend out as normal. You should be OK.
If not, let me know and I'll see what else I can dig up.
The last thing you can try is updating the Firmware. Below is a link to the Firmware update for this camera. Since I don't know what OS you're using, just pick your Operating System and follow the instructions on the pages that follow the link you chose.
Dec 04, 2010 | Olympus FE-210 Digital Camera
Fe 5020 digital camera plastic tab that holds battery in broke off and now receive an error message that the card cover is open
The base is working as a complete circuit when it is closed completely. Now as the plastic tab which holds battery is broken so the circuit is not getting completed and the software of your camera is not getting message that all parts are functioning accurately. You need that plastic tab or similar tab to fix this problem. Please show your camera in a repair shop and they will get it fixed at very low prize as they normally have such parts with them.
May 29, 2010 | Olympus FE-140 Digital Camera
Olympus FE-210
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 10, 2009 | Olympus FE-210 Digital Camera
Broken battery compartment lid
you could but the cost and time would not be worth it,just find you some gray electrical tape,works wonders,but make sure you press down real firm while putting a good solid peace on ok. good luck hope i helped.
May 01, 2009 | Olympus FE-210 Digital Camera
Write Protected. What does this mean?
no, there will be a small button on your memory card just 'slide' it the opposite side. its on protect mode.
Apr 08, 2009 | Olympus FE-210 Digital Camera
Formatt memory card and battery empty!
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from or
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Accepte My Greetings
    Oct 25, 2008 | Olympus FE-210 Digital Camera
    i have a olympus FE 210 i had this less than a year ago when my memory card is in the camera the camera does not turn on but when i remove the memory card the cam works fine. please Help
    Jul 24, 2008 | Olympus FE-210 Digital Camera
    Olympus fe-210 fault
    i think u need to change some small componnt in power board.
    Jun 16, 2008 | Olympus FE-210 Digital Camera
    How to put memory card into Olympus fe-210 digital camera
    Did you buy the proper memory card? Your camera supports only XD cards.
    Dec 28, 2007 | Cameras
    Cameras Logo
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
