SOURCE: ps3 green and red diagonal lines
make sure setting are correct for blueray and games,trying disabling some,trial and error.
Xbox fanboys answer says it all,maybe if he took his xbox apart and found parts from every third world country ,i am on my third elite console love ring of death.
SOURCE: ps3 video settings
you dont need an hd tv or even cables for hd. all you have to do is readjust your output settings, you can still use the cables that came with the ps3. for example i just had to change mine to 16:9, i thiink thats the right numbers, under composite cable and save the settings, im pretty sure you have to change it back for other games though.
SOURCE: every time i put in the heavenly sword cd , the
You must make sure your ps3 has been updated to the latest software, aswell make sure all the patches have been downloaded from the game. If your ps3 is online this should be easy to solve if not you will have download the updates on your computer to a flash drive then plug it into your ps3 to update that way. If there is still a problem your ps3 maybe over heating check the disk and make sure there are no scratches and if there is still a problem call sony tech support you can get there number online. Worst case senario you can send your ps3 to them and they will fix it free of charge and i know this becuase ive sent them mine before. Good Luck.
SOURCE: PS3 games won't load
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
