Question about Dryers
Kenmore Elite Dryer, model#11062942100. Push button to start and it won't stay on once you release the button. The dryer doesn't seem to be heating either.
  • jmbcantu Feb 26, 2009
    I have the same problem with my dryer. Where can i get this part to fix the panel?
    jmbcantu@comcast.net
  • Larry Youngblood
    Larry Youngblood May 11, 2010
    you need a microcomputer part number 8564229 to fix your problem / it is located inside the top console / if any problem locating one contact me and i will see if i can help you out.
    larry
  • 706 Answers
In all probability, you have an open thermal fuse in your dryer or ( depending on the model) you may have a motor switch that is not making the circuit remain on. These switches use centrifigal force ( when the motor rotates up to speed ) to keep it on so that you can release the start switch. Hope that helps..
Posted on Nov 26, 2008
Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Oct 15, 2012 | Kenmore Dryers
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
Our dryer doesn't stay on when you hit the start button. It turns off when you release the button.
The seal in ccircuit for run usually goes through a switch in the motor, whitch if it sticks or the switch goes bad, it wont stay running.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Need to replace the heating element in my Kenmore Elite Model 11062942100
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11062942100/0582/0151200/P0103155/00003?blt=06&prst=0&shdMod=11062942100
Hello tarkington, here is a parts diagram to start with. To replace the heating element, all you really need to do is take out the old one, and hook up the new one. It's that easy.Here is a video to help you with disassembly if needed.
http://www.youtube.com/watch?v=2bVoelV7M7Y
And finally a video of a heater element being replaced. It's not exact to your model, but it might help.
http://www.youtube.com/watch?v=_yL-WO_eRic&feature=relmfu
I hope that you find this helpful. I will be more than happy to help if you need any further assistance.
thanks,
Mike
Jul 21, 2011 | Dryers
Have a kenmore elite quiet pak ll gas dryer start buton doesn't start. when release the button dryer stops
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
Jul 02, 2010 | Kenmore Dryers
Dryer will not stay running
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Kenmore Elite Dryer button won't stay on - no heat
There is a switch on the motor, (centrifugal) that bypasses the push to start once the motor is turning. It is in the heat circuit also. Look there first...Eric
Jun 14, 2009 | Kenmore 63942 Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
322 people viewed this question
Top Dryers Experts
Marvin
Marvin
