Question about Microwave Ovens
1) What's the expectect temp range for 1L water, for GE load test for 1KW ovens? 2)Why didn't my brand new oven come with a repair/maintenance packet like my old one did? Tom
1L for 2.5 minutes should increase temp 25-40 deg.
Posted on Nov 28, 2008
  • Microwave Ovens Master
  • 9,098 Answers
1) MICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or by 70 if you're using a centigrade thermometer.
2) If it's not
hidden either behind the grille or control panel, they may have left it out as a cost-savings measure.
Posted on Nov 27, 2008
How do I unlock my microwave
all brands Microwave Display Repair circuit board repair ...
031d26d.namesecurehost.com/mwd/?3e3ea140
Jul 1, 2015 - All brands Microwave Oven Display Repair brand nationwide Sharp Dacor GE G.E. General Electric Samsung Kenmore Frigidaire Whirlpool free help tips. ...Press the "Custom Help" pad and follow the on-screen instructions to unlock the oven....... MH6150XLT-1 MH6150XMB MH6150XMQ MH6150XMS ...
Aug 04, 2015 | Whirlpool MH6150XMS Microwave Oven
Ge oven membrane panel
Order GE range/stove/oven parts today. We ship GE range/stove/oven parts on time or your order is free. Return any GE range/stove/oven part for any reason for one full year. Customer service for GE range/stove/oven parts is available 7 days a week. More than one million parts available. We stock the GE range/stove/oven parts you need for immediate shipment. We have more than 200,000 high-resolution part photos.
Jul 26, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Locate light switch Light switch does not turn off light Tested microwave--heats water ok
Since you didn't mention the model number or which light, I have to be kind of general.
I would bet that the light you're talking about is either the cavity light or the cooktop light.
Either could be stuck on due to a shorted relay on the control circuit board, which we regularly repair.
There's also a chance it may be a bad door switch or door switch mount. See my text file on that here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
For most brands, you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Sep 29, 2011 | Daewoo KOR-1B4H Microwave Oven
My microwave oven is dead. Apparently the fire protector blew. How to locate and how to replace?
Since you didn't mention the model number, I have to be kind of general.
If you mean the flame sensor or oven cavity thermostat, they are usually located on the top of the cooking cavity, so you would first have to remove the oven from the wall mount if it's an over the range type.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If for some reason you don't still have your installation instructions, y
ou can download GE owner's manuals and installation instructions here.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can download Frigidaire owner's manuals and installation instructions here.
You can download Samsung over the range microwave installation instructions here.
You can find links to other brands and find helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Then you can remove the outer cover to access the parts.
Sep 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave was manufactured in 1984. just recently started shooting out sparks? Do I need a new one. Doesnt work well
Sparks are a bad thing - I would go new or used from Craigslist. Just check that it works. GE performance test: Heat 1 liter of water for 2:03 at full power, should raise by at least 35 degrees @120V. Record starting temp and ending temp (no cooler than 59 to start).
Nov 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Microwave Oven with an F1 error code
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 11, 2010 | GE Profile Spacemaker Over-the-Range...
How to clean GE Advantium???
Get a stainless steel "brillo pad" at the grocery store.
When you get home ... put a microwave safe container with water inside it ... in the oven. do not heat for more than 2 minutes!!!!! The resultant steam will soften the gunk. Use the stainless steel cleaner pad gently to remove the goop.
I hope this helps you
a
Sep 23, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
If i will cook in 2 minutes,wht should be the right tempereture?
Depend your setup the power level and what is you cook and it defferent from 1 MWO to another
Here how I test MWO after repair use 1 plastic can fill up about 1L cool water from the tab set MAX power level and set for 2 min the temperature should be between 82C to 87C base on NEC MWO
I hope that would help you
Dec 02, 2008 | Panasonic NN-SN657SMicrowave Oven
Microwave Ovens Logo
120 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
