Question about Lexmark X4550 InkJet Printer
Printer not connecting
I was using my lexmark x4550 when we had a power cut, now the red lights just flashing and not going yellow, im using it wirelessly, please can you tell me how to fix it.
  • Lexmark Master
  • 19,396 Answers
To start do the following:
Unplug printer for ten minutes.
Empty printer cue.
Take out cartridges and put them back.
If that does not work reinstall the printer software form disk provided with the printer.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Posted on Nov 30, 2008
AC/DC Adapter for Lexmark X4550
Google the Internet for a power adapter for your model printer.
You will get various suppliers and prices.
Jan 31, 2013 | Office Equipment & Supplies
I HAVE LEXMARK X4550 - when I open lexmark imaging studio i am told to use the controls on the printer. This is ok when i want to scan but if I want to use ocr option I am not given the choice. I am sure...
There could be a problem with your printer software. Please insert your printer software installation CD into your computer hard drive. Execute the application to repair any possible corrupted printer software files.
Mar 03, 2012 | Lexmark X4550 InkJet Printer
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Lexmark x4550 scan problem
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/g8G3VP. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 13, 2011 | Lexmark X4550 Multifunction Wireless Color...
Lexmark X4550 3 in 1. Although the wireless capacity has been loaded and activated it has ceased working and will not allow access.ie the flashing wireless connection light does not turn green just...
Try to reset the printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Wireless Setup > Reset Network Adapter > press check to confirm.
Re-launch the Lexmark Wireless Setup Utility to connect the printer to your network. If you have a firewall enabled, make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall. Also, place your printer where it receives excellent wireless signal quality and away from other electronic devices which can cause wireless interferences (e.g. cordless phones, microwave ovens, baby monitors, garage door openers, and other wireless electronics).
Jun 27, 2011 | Lexmark X4550 InkJet Printer
I am unable to configure my X4550 to my wireless network.
It could be due to some blocked printer communications - a firewall maybe? What is the status of the wifi light on your Lexmark printer? This article will help you determine and resolve your wireless connection problem: How to identify a Wireless Communication Problem and Resolution Tips.
May 02, 2011 | Lexmark X4550 Multifunction Wireless Color...
How can I restore factory settings on my Lexmark X4550? I changed wireless hubs and it won't connect, so uninstalled and re-installed but can't complete the set-up as some settings are saved in the printer...
Hold down the power button until the Lexmark X4550 is off.
Hold down the 'Settings' and 'Start Colour' buttons.
Press and release the power button.
Wait for 'Language' to appear on the screen. Release the 'Settings' and 'Start Colour' buttons.
Hope that helps anyone else who has this problem.
Will
www.fixitrepairs.co.uk
Sep 29, 2009 | Lexmark X4550 Multifunction Wireless Color...
My power supply is dead how do I order a new one.
You can get one from lexmark, or off of ebay. Your power supply will say how many volts it outputs.
Match this up with new one
You also get one from
www.newegg.com
www.argecy.com
or others. Just type in your model #
Aug 04, 2009 | Lexmark X4550 InkJet Printer
Lexmark X4550 InkJet Printer Logo
137 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
