Question about Mitsubishi WS-65809 65" Rear Projection Television
VERTICAL BLUE LINES ON MY MITSU WS-65809
I GET VERTICAL BLUE LINES ON MY SCREEN WHEN I TURN IT ON AND DONT KNOW WHAT IT IS FROM..I HAVE BEEN TOLD IT COULD BE THE HDMI OR THE CONVERGENCE IS GOING BAD BUT WHAT SOME OTHER OPINIONS...ANYONE HAD THIS PROBLEM B4? ANY HELP WOULD BE AWESOME
  • 1 more comment
  • boulder40 Nov 28, 2008
    they start at the bottom and go all the way up and are evenly spaced apart no curve to them and straight as can be they are thin though
  • boulder40 Dec 01, 2008
    i took the blue crt board off and the lines went from blue to red, but before i was wiggling the wire that is in the front of the bulb and the lines were going in and out, not the whole line but some of it.....this is gonna sound dumb but how do i tell if its open and if it is what do i do then
  • Sonny Berry
    Sonny Berry May 11, 2010
    Do the lines start at the bottom and cover most of the screen and appaer curved thin lines? or are they just around objects?
  • Mitsubishi Master
  • 8,617 Answers
Its either the Blue CRT or the Blue CRT drive Board which is causing the lines, More probalble would be the Resistors on the CRT board. I would recomend unsoldering one side of each resistor on the Blue CRT drive and lifting that end up out of circuit and checking, one may be open which would cause that symptom
Posted on Nov 28, 2008
Convergence Adjust
It means probably one of the two convergence ICs has blown
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Mitsubishi VS50805 Serial # 102718 No red in picture
Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
http://servicemanuals.vstore.ca/
Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
CONVERGENCE IC ADJUSTMENT
My KP-46WT510 picture is out of alignment. There is no conversion of the red, blue and green pictures on the screen. They're off by about an inch of each other.
Some tech told me that it was the power control that was bad. I can see the picture, just very blurred.
Is he right? The tv was not move at all before this started happening.
Oct 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Rear Projection TV convergence
dear friend if you have that type of skills you cerlainly can either resolder or replace the convergence stks. you we'll need to replace both if that's the case. they look like the audio outputs in the audio amplifiers. good luck
caypianan@yahoo.com
Oct 12, 2008 | Televison & Video
Convergence
if the blue lines runs across the screen in the center its a vertical deflection problem it will need to be diagnosed.
Oct 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
Mitsubishi WD62530 62 in. HDTV LCD displaying blue vertical lines
i just got the same tv today and the same thing happend to me but it happend with the satellite input and i did not have the blue vertical lines i just had a black screen and sound. i unplugged the hdmi cable that carried the signal to the tv and plugged it back in and i had a picture. hope this helps
Dec 17, 2006 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WS-65809 65" Rear Projection Television Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
