Question about RCA HD50LPW175 50" HDTV
TV sparking when hooking up cable
I just moved my tv into my new home and the tv turned on fine but when the cable guy went to hook the cable up to it would start sparking. I did not know if anyone knows how to fix this problem.
  • 1 more comment
  • lite7251 Nov 26, 2008
    The connector for cable. Everytime the cable guy plugs the cable into the back of the tv there is a spark and a popping sound.
    Thank you for your help. Around the connector for the cable now is black, like it is burnt. The cable guy said when we intially unplugged the cable while moving it might have stripped a wire and that is causing the spark.
  • robwan
    robwan May 11, 2010
    What exactly is sparking? The connectors, the actually TV? is it sparking when you try and plug something into it?
    Problem Solver:
  • 20 Answers
Hi, there is a sparking sound probably because whatever your cionnecting it from is still on. So switch of the unit where the cable is coming from, maybe its froma signal booster? and plug it into your tv, also there maybe still current running through your tv so switch off your tv aswell. It is quite common for connectors to spark when the equipment is on because the connector is try to make contact and there is a voltage present. I'm guessing that the TV works fine once the connector is inserted in or hasnt your cable guy gotten that far yet?
As long as its not a large spark and the source which the cable is connected to is not a high voltage source, which I dont see any reason why it should be. Also check the grounding of the cable. Considering you have a cable guy installing the equipment I'm suprised they do not know whats going on.....
Regards
Rob
Posted on Nov 26, 2008
  • robwan
    robwan Nov 26, 2008
    Sorry for my terrible spelling errors but I hope it makes sense.
Remote does not work
Infrared sensor inside the TV is damaged. Replace it.
May 17, 2013 | Televison & Video
Samsung 42" Plasma HDTV cable hookup problem
There sould not have been sparks. Check the following: Using a voltmeter check between the cable itself and ground. There should not be any reading (anything less than .1V is normal). Check again between the inner hole of the RF connector and the outside part. Again there should be less than .1V. If you read any voltage at the RF connector, the TV is faulty and should be exchanged. If you read voltage at the cable, have teh cable company check again.
Dan
Jul 30, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
Power went out - hooked up tv to generator and now
hi,
pull out the fuse of your television and replace it a new one.i hope this may help you.
regards,
kaybicks
Feb 27, 2010 | Toshiba 40RV525U 40 in. LCD TV
Cable Guy messed up Bose 18 sound
Make cable guy get you one.I cant believe he left without fixing it.
Sep 20, 2009 | Bose Lifestyle 18 System
Went from HMDI to standard cables=no picture and no sound
reset your settings on the ps3 on your old tv using the same set up then go to the new tv and it will come on. I had the same prob
Apr 27, 2009 | Sony Playstation 3 (PS3) Console
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Jan 09, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
RCA HD50LPW175 50" HDTV Logo
277 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
