Question about Dell Wireless Keyboard Optical Mouse w0147
How to turn-off Dell Bluetooth Mouse when computer is off
I knew how to turn it off through switch in the mouse. I wanted to turn it off automatically when computer is turned off.
Thanks
    Genius:
  • Dell Master
  • 1,102 Answers
They usually don't have that option
the mouse shts off when computer harddrive and monitor turn off
Posted on Jan 26, 2009
How do I sync the mouse up so I can use it?
'Synch the mouse up'? You mean connect via Bluetooth? They are either Bluetooth to Bluetooth or Bluetooth to USB dongle.
Blue to Blue. Switch on the device you are connecting to and enable Bluetooth. Switch the mouse on, when the device finds it, click Pair.
Mouse to computer or laptop. Remove the USB dongle from the recess in the underside of the mouse. Plug it into the computer or laptop, switch the mouse on. Plug and play will connect it automatically.
Apr 08, 2016 | Computers & Internet
My dell mouse wm311 quit working. i got a new dell inspiron 15 laptop Saturday and the new mouse worked. the next day it wouldn't work. the batteries test fine. it is turned on but it won't work.
Your mouse has probably lost its pairing. There should be a button that puts the mouse into answer mode so that when the computer looks for it, the mouse will be found and paired. All you should have to do is get the computer up and running, then turn on the mouse and push the button that makes it answer. (Should be a power switch and then another push button switch that allows the mouse to respond to search queries from the computer.) Then after a few seconds try moving the mouse to determine if it was found. If not found, then try going to devices to make sure it is searching. The mouse should show up on the list of devices.
I have the Microsoft 5000 Bluetooth mouse and it auto pairs. But if I turn it off, it will lose pairing. Sometimes I forget that I didn't turn it off and it is not clear which position of that tiny power switch is the ON, but when I push on the answer button, a light turns on to let me know that power is on. If the mouse is found or if it can't pair, the light goes off so the only way to tell that it is paired is to see it move the mouse pointer. So far it works quite well.
Mar 10, 2011 | Dell U0636 Mouse
Driver for Dell BT Travel Mouse
If it is a dell mouse, it should automatically work after a few things. Simply locate the button on your mouse to power it on, open your bluetooth settings on your computer and scan. It will then add the drivers as a HID (human interface device). If that fails go to dell.com, search for drivers & downloads under support and search for the drivers & documentation.
Mar 31, 2010 | Dell Studio 17 Laptop
My bluetooth mouse used to connect but now it doesn't...When I press the blue button, the blue light does not blink like it used to. Is my bluetooth mouse dead? (fresh batteries, and it turns on).
Mostlikely you need to repair the mouse with the computer. open your bluetooth utility or the keyboard/mouse utility and follow the pairing instructions. this should solve your problem
Feb 12, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Bluetooth keyboard and mouse stopped responding on Dell Dimension E520
try to insert another usb drive on the port.it the usb works then probably the bluetooth transmitter is faulty. If the USB drive also does not work... then probably the USB port of the computer damaged.
Jan 15, 2018 | Dell Wireless Keyboard Optical Mouse w0147
CANNOT CONNECT WIRELESS MOUSE TO DELL INSPIRON 1525
make sure your usb ports are turned on in the bios
Apr 11, 2009 | Dell Inspiron 1525 Notebook
Installing a French ( Brand is Genius) keyboard to my Dell computer.
Pair to a Bluetooth Device (new and re-pair)
  1. Locate the Bluetooth icon in the lower-right corner of the computer screen, and compare the status to Table 1.
    (The Bluetooth icon may be hidden, click the Show hidden icons arrow to show any hidden icons.)
    Bluetooth Icon Status Enabled - The Bluetooth adapter is ready to pair with another Bluetooth device.
    Connected - The Bluetooth adapter is already connected to a Bluetooth device (if the desired device is not the one its connected to, it will have to be re-paired). Disabled - The wireless switch is off. For information on how to turn the wireless switch on refer to the
    Online User's Guide. None When no icon shows the Bluetooth driver needs to be installed, refer to Dell Knowledge Base Article:
    "How to Download and Install the Latest Dell Wireless Bluetooth Driver" Table 1: Bluetooth status
  2. Verify the following conditions have been met:
    • Batteries are Installed in the Mouse and Keyboard.
    • The Bluetooth adapter, USB Bluetooth adapter or 13/19-in-1 Media Card Reader is installed in or attached to the computer.
    • The latest version of Dell Bluetooth Wireless Keyboard and Mouse Bundle is installed,
      if unsure refer to Dell Knowledge Base Article: "How to Download and Install a Driver"
    • The Bluetooth device you are going to pair is within 30 ft. (10 meters) of the computer.
  3. Right-click the Bluetooth icon in the system tray.
  4. Click Add a Bluetooth Device.
  5. Turn on the Bluetooth mouse and press the Bluetooth connect button on the bottom of the mouse. The Bluetooth LED on top of the mouse should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  6. Click Next to start searching.
  7. Click the icon for the mouse to highlight it and then click Next.
  8. The connection is set up automatically. Once the connection to the mouse has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the mouse indicates it is connected.
  9. SetPoint will now launch and ask to check for updates, click OK. If an update is available click to download it.
  10. After the update has been applied, click OK.
  11. Turn on the Bluetooth keyboard and press the Bluetooth connect button on the bottom of the keyboard. The Bluetooth LED on top of the keyboard should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  12. Click the box next to My device is set up and ready to be found and then click Next to start searching.
  13. Click the icon for the keyboard you want to connect to in order to highlight it and then click Next.
  14. When the keyboard is connected, the Confirm Keyboard Connection screen appears. A passkey that has been generated for the keyboard is shown. Type in the passkey as it is shown on the screen. Note:
    The keyboard can only store one passkey. The passkey is unique to each computer. If you try to connect the keyboard to more than one computer, the passkey is changed each time you create a connection.
  15. The connection is set up automatically. Once the connection to the keyboard has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the keyboard indicates it is connected. You are now be able to use the devices.
Aug 25, 2017 | Trust Silverline Direct Access 12879...
Dell Wireless Keyboard Optical Mouse w0147 Logo
220 people viewed this question
Alun Cox
