Question about HP LaserJet 1200 Printer
Grinding noise in cartridge for hp laserjet 1200 series printer. I replced cartridge and still hear noise sometime worse and then not so loud.
  • yenuha Dec 30, 2008
    i have same problem what will be the solution
  • 231 Answers
I have the same problem and I know what is causing my problem. It's not in the cartridge. You're laser scanner is going to go bad. I had the problem 3 months ago. I would only make the grinding noise when it powered up. Printing was okay. I don't use the printer that much. Then about a week ago I notice only the bottom diagnostic light was on. I unplug the power and powered it back up. The grinding noise got louder and wouldn't stop. I unplugged the printer an replugged. Same thing.
I was bored (christmas day) and decided to open my printer to see what the root cause problem was. I removed several screws and once I got all the printer naked (removed all the plastic outside). I plugged it in an tried to listen where the problem was. I notice a vibration at the laser scanner (top black piece). I unplugged the printer. I unplugged the power source to the laser scanner. Replugged the power and saw all the gears move with no noise. Powered off. Replugged laser scanner. Powered on. Noise back. Defective laser scanner. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps.
Posted on Dec 25, 2008
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
Dec 20, 2012 | HP LaserJet 5200 Printer
When i power up the printer it make a loud noise. It appears to come from lower area below the cartridge. it makes the noise even if the cartridge isn't in
If this is a grinding noise it will be the gear assembly near the fuser on the printer. You would need a printer repair person to fix this for you.
Mar 08, 2011 | HP LaserJet 3320 All-In-One Printer
If my printer is squeaking what could be the problem besides the toner cartridge?
Squeaking noise is usually caused by the toner cartridge, expecially after market ones. But if its not the toner, I've seen the mirror motor cause a rotation noise in the 1300/1200 series printers.
Nov 18, 2010 | HP LaserJet 1300 Printer
Hp lasserjet printer 1200 motor will not stop with a loud noise
It could be a flipped wiper blade in the printer cartridge. Does it make the same noise if you take the cartridge out? If it does not then you should try rotating the green drum on the bottom of the cartridge towards the back of the cartridge (the bigger half) and then reinstall it. If it persists and you're fairly positive it is the cartridge installing a new one will fix it. If it is not the cartridge the machine might need servicing. We are fairly proficient with laser printer repair in our Cartridge World store, and our corporate office started recommending similar training nation wide for our stores. I would call you local Cartridge World and see what they can offer you.
Oct 29, 2010 | HP LaserJet 1200 Printer
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
Hp laserjet 1200 series printer with high pitch nose when in printing process. During this loud noise, the roller turns but the paper is not picked up therefore printing does not occur.
noise is caused by the toner cartridge and paper is not going trough because there is a plastic milar clse to the feed roller that is bent,find it and push it towards the inside of printer (is a black or dark brown plastic mylar)
Aug 24, 2009 | HP LaserJet 1200 Printer
Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
May 29, 2009 | HP Color LaserJet 2550n printer + HP Color...
Hp 1200 laserjet printer generates a lot of noise from the laser cartridge
I would leave the printer off and contact your printer's technical support department and let them know and they are the professionals specifically for that and they would be able to give you an answer and provide you with choices to fix the problem!
Oct 26, 2008 | HP LaserJet 1200 Printer
HP LaserJet 1200 Printer Logo
431 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
