Question about Sanyo DS24425 24" TV
Sanyo ds24425 TV comes on automatically
My television is coming on automatically at different times of the night. I'm able to turn it off via the remote but it's a hassel when it comes on @ 330am and wakes us up! help!
  • Sanyo Master
  • 5,568 Answers
Time to call Ghosthunters? Sorry, could help myself.
Try this: put a couple of Postits or similar over the IR port on the front of the set to see if this makes any difference. If it does, then you have some source of infra-red somewhere in your home and the set is responding to that.
If it doesn't, then the circuitry beyond the IR sensor is having problems and it is not likely that you can repair this yourself although you can take a look.
Unplug the set for at least hours, preferably overnight, to allow the stored charges in the set have time to bleed off. If you don't you may get a nasty (but rarely fatal) shock since aside from the 25,000 volts used on the picture tube, there are parts that may have hundreds of volts with far more stored energy than the CRT.
After removing the back of the set, look toward the front from the inside and see if the IR receiver is mounted on a separate board which is quite common since the Asians are smart and often buy such common subassemblies from specialized companies and install them during the manufacture of the set.
If you can see such a board, check to see how difficult it is to access since you will need some kind of part number which (hopefully) will be on the board. You may find several so: if the number appears to be similar to the printed circuit traces, it may be only the number for the bare board. Look for one on a paper label or a number that is stamped; this is how the finished assemblies are normally marked.
I don't know how good (or bad) Sanyo is for replacement parts of this kind but I would give it a shot to see if you can buy the board and install it yourself. My experience with some of them has ranged from excellent to 'forget about it.'
Posted on Nov 26, 2008
Sanyo DS24425 turns on an then shuts roght off
Check plugs going to the lcd panel from the inverter board. Check ribbon cables going to the inverter board.
Nov 15, 2011 | Sanyo DS24425 24" TV
Need unversal tv remote GE, for sanyo tv...
try walmart / bestbuy / jandr.com or even duane reade for universal the codes for sanyo is in the booklet that come with the remote...look at the type 3 to 6 (depend on how many items you want to control w/ remote) tv/dvd/vcr/cable box etc
May 20, 2010 | Sanyo DS24425 24" TV
Factory reset
in thid you have reset you tv with help of tv remote . this syestem is used because while seeing at night some oerson sleeps. so he set timer after which the tv gets turned off. to solve this you have to go in menu and you to search for a tinner or sleep option it can be directly on your tvv remote
Jan 30, 2010 | Sanyo DS24425 24" TV
Have lost the instuction guide to setting up the tv
Click HERE to download instruction manual copy of Sanyo DS24425 TV
Thanks.
Sep 18, 2009 | Sanyo DS24425 24" TV
RCA universal remote
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
Sanyo DS24425 TV Has No Picture and Very Faint Audio
DONT BUY SANYO ELECTRONICS THEY ARE JUNK
Jan 09, 2008 | Sanyo DS24425 24" TV
Sparks
Where exactly are the sparks coming from? If you remove the back of the TV, can you see exactly where the sparks are coming from?
Sep 14, 2007 | Sanyo DS24425 24" TV
Tv wont come on
i think it's the built-in power surge/failure sensor.  Plug the TV into the wall and press RESET on the remote twice.
Jul 07, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 24" TV Logo
79 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
