Question about Technics Audio Players & Recorders
Error code F61 on Technics SC-DV150
Does anyone know what the problems are and if it can be fixed without going to a dealer?
    President:
  • 624 Answers
The F61 error is an amplifier failure.This error can be caused by a blown channel or even a failure in the power supply which causes the unit to detect an amplifier failure because the power supply is not supplying the proper voltage to the amplifier. On more rare occasions this can be caused by broken solder connections in the amplifier and/or power supply. Without having the receiver in front of me to troubleshoot it is impossible to tell you exactly what the cause is.
It can be fixed, but it will require some decent electronic skills. If you do not have a multimeter, soldering equipment, and an understanding of electronic components it would be best to let a service center look at it for you. If you do have these tools and would like to try and fix it yourself, let me know and I may be able to guide you thru the troubleshooting process.
Dave
Posted on Nov 26, 2008
  • HAYOP30 Jan 31, 2011
    hi, i have the same problem, and have a level of 7 out of 10 skill in electronics. i also have all the necessary tools, but need some assistance if where to start. thanks
  • William Forster Apr 30, 2013
    I think I just fixed the same problem, waiting to see if it still works. My theory is that a wire has crossed somewhere in the center speaker, creating a short which heats up the amplifier. I had also placed stuff over the vent at the top of the amplifier. Therefore the fix is to let it cool overnight and check the speakers with a multimeter to see they are roughly 8 ohms.
How can I correct F61 error?
See page 37 of the user manual.
Get from lil given here.
Error F61
Check and correct the speaker cord connections. If this does not fix the problem, there is a power supply problem. Consult the dealer.
http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
Feb 01, 2016 | Panasonic SC-HT730 System
My technics hi-fi separates sL-EH790 is not coming on just saying f61 then going off
Hi Shelly,
"F61" is an error code for short and/or overload detected by the processor upon self check.
First thing you have to try to eliminate this kind of symptoms is by disconnecting all of the inputs and speakers connected from the unit then turn it on without them. Let me know if the symptoms still persist...
Jdvillanueva
Oct 22, 2011 | Technics Audio Players & Recorders
Why my dvd players show error f 16.i aslo cant`t on my player and then the error dissappear.why?
Are you sure you are not getting a code F61? I don't see in the manual a code f-16. It's says to "When a unit displays F61 - check and correct the speaker cable connections, If this does not fix the problem then consult the dealer." That is strait out of the manual for your theater system. I have uploaded a couple of diagrams to aid you with double checking your wiring. Should this not work then you must contact your dealer.
Regards,
Tont
Apr 18, 2011 | Panasonic SC-HT895 System
Stereo does'nt stay on you turn it on and it just clicks n goes off technics dv290 system
problem with amplifier contact dealer,i have the samne problem with mine,its shows F61 on the diplay and when i check my user manual it states there is a problem with the amplifier
Dec 09, 2009 | Technics SC-DV290 System
Stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Oct 15, 2009 | Audio Players & Recorders
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Aug 30, 2008 | Panasonic SC-HT700 System
F61 problem
DIsconnect sound Amplifier ic (RSN).After removal of the ic if the unit works o.k offcourse without sound than replace ic.If still f61 than sound ic is o.k and check voltege regulators in power supply.You can check dc detect line if it gets activated.
F61 is mainly two resons 1st sound ic or power supply problem in power bord which send signal to system control to shut down the power in order not to damege more.
Dec 13, 2007 | Technics SC-EH780 CD Shelf System
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
Code f61
you need to service your system,if you go to www.technics.co.uk and go to dealer locator to find a local service centre it might be costly to repair but find out before you go any further
Jul 13, 2007 | Technics SC-DV290 System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
828 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
