Question about ViewSonic OptiQuest Monitor
Resolution Problem with 2 Optiquest Q19WBs and 1 GeForce 8600GT
I have 2 Optiquest Q19wb (Analog/VGA) LCD Monitors, running off of 1 XFX GeForce 8600GT Graphics Card (1 @ VGA Out, 1 @ DVI Out (w/adapter)), running on a GigaByte Motherboard.
I have been in contact with my MB, Graphics and Display Manufacturers, regarding 'Drivers', et al, and there has been alot of head scratching, but no resolution to my problem.
Whether I have EITHER of each Monitor hooked to either Output on the Card (1 at a time), or BOTH hooked to EITHER Output at the same time (2 at a time), if I go above 800x600 res on either Monitor, that Monitors Image moves DOWN & RIGHT, rather severly, and using the On-Screen Adjustment, does NOT help.
  • Whassupwidat
    Whassupwidat Dec 18, 2008
    I have Tried BOTH Monitors on another System I've got (Only 1 VGA Analog Out), AND Both Monitors on a friends System...
    I KNOW, that it's NOT the Card, since I have another 8600GT, and BOTH Cards, work in adjacent Systems.
    I'd HATE to think, that the Motherboard is causing, but, if so, I'll try an SLI Motherboard, with both of my GT's. BUT to fork over coin, on the chance and then STILL have the Problem, would ****, Big Time...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, what motherboard pls? And has it been flashed to the latest BIOS?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 26, 2008
  • 849 Answers
You could connect both monitors at a time but after installing the card drivers. the driver installation will enable you to achieve high resolution as well.
  • ViewSonic Master
  • 13,433 Answers
Possibly a problem with the monitors, have you tried other monitors with this? other than that a fault in the card or windows video positions are messed up, try adjusting the nvidia .. screen position.
My monitor all of a sudden turned yellow so the whole screen is hard to see.
it seems that this problem occurs because of faulty VGA card or may be your VGA adapter got damaged.if it is then replace your VGA adapter
Jun 01, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
Please help me my optiquest q19wb model #vs11443 is shuting off aftre 1 second i opened it and no capacier were damadged what is wrong... the unit is not old 2 years i am not rich and want to save...
The usual problem with this symptom is an CCFL power supply failure. The inverter is the board that powers the backlights so you can see what is on the screen. If you look really close and with a flashlight, you may be able to see the dark shadow of the image on the screen. Without the backlight, the LCD is useless.
You can get parts from places like http://www.lcdalternatives.com/ or eBay. Search for the model number and "repair" (e.g. "Optiquest Q19wb repair") on eBay.
Apr 12, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
Changing resolution
Greetings, changing of your desktop resolution is explained in my published guide entitled How to set your Desktop Screen Resolution?
This will increase in clarity of your picture and give you a better experience.
Thanking you
damnor01
Aug 21, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Viewsonic Optiquest Q19wb lcd Monitor goes blank after 2 secs. A couple of posts say replace the 1000uf 16v Cap My problem is i can't find them on the pcb (where are they?)
Look at the board where the AC power connector comes in that is the power supply board, there are more than one versions so it nay not have the same caps value.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic/Optiquest monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Post pictures or send them to me budmrtn@aol.com
May 15, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Trying to get 2 monitors working
plug your LG display into the DVI port and the BENQ into the VGA? it may just be a random compatability error.
May 04, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
Q19wb Monitor Replacement Part Numbers Needed
Look on eBay for "Optiquest Q19wb repair" or "Optiquest Q19wb power"
This is a common failure mode. You can either buy a set of capacitors and solder them in, or buy a replacement power supply board if you cannot solder.
One eBay seller notes the power board as an ILPI-025, which is common among the following models:
Power Board ILPI-025 For LG W1934S & Viewsonic VG1930WM & Optiquest Q19WB & Acer AL1916W Ab etc
Model:ILPI-025 REV:E 79069140
May 29, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Just let Windows install IE 8 and now the desktop picture is over
Change the resolution. Right click in the middle of the screen over nothing, and select properties then select the settings tab and move the slider left for larger resolution.
Apr 28, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Have a new 23 inch samsung monitor that requires res 1920x1080
The problem is the cable connection to the video card.
When using the DVI output of the FX 5500, the maximum screen resolution that you can select is 1280 x 1024.
But, if you use the Analog (VGA) output, the card will support resolutions up to 2048 x 1536, which should be ok.
Apr 23, 2009 | XFX GeForce FX 5500 Graphic Card
DUAL MONITOR RESOLUTION
At a guess it is the refresh rate the video card is sending to the video out. What is the Max Resolution of the monitors and refresh rate ??
I would think there is a program to be able to setup the driver refresh rate and resolution don't use window drivers get the ones from the makers of the card rather than using the default nivida drivers
Mar 24, 2017 | ViewSonic OptiQuest Monitor
Computers & Internet Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
