Question about Kitchen Ranges
My mouse dase not work properly . i have to push down and keep holding the usb connector. some time i have to push up or side .can you help me thank you
Check the usb connector. If the part that fits into the usb port wiggles, it's time for a new wireless mouse. I had the same thing happen to me with a Microsoft Wireless mouse.
Posted on Dec 02, 2008
Describe how to turn on a kensington pocket mouse
The first thing you gotta do is insert two AAA batteries into the mouse. The batteries are supplied -- and in my case at least, they were Energizers -- but the battery cover is very difficult to get off. All I can tell you is -- keep pressing down and forward, like the instructions say, and eventually you'll get it. You just might sweat off several pounds first.
The next issue could have been avoided if the instructions had simply told me what NOT to do. (I subsequently emailed Kensington and WAS told NOT to do it.) To connect the cordless mouse, you plug a tiny receiver into the USB port in lieu of a cord. But you MUST use a port on the computer itself. You CANNOT plug the receiver into a USB hub. If you try to, the receiver's pilot light will light up, but you won't be able to establish a link with the mouse.
With the receiver properly connected, establishing the link involves simply pressing a button on the receiver, then pressing the "connect" button on the mouse. When you press the receiver button, the pilot light starts to blink. When you establish the link, the pilot light glows steadily, but flickers each time you move the mouse. The linking procedure is simple enough, except that the `connect" button is recessed into the bottom of the mouse, and thus needs a pen or some similar object to press it.
After doing all this, I still thought the mouse wasn't working properly, but to be fair, this issue WAS covered in the instructions. This optical mouse is picky about the surfaces you use it on. It turns out that the worst surface to use is a black, reflective one -- which exactly describes my computer table. After putting the mouse on a sheet of white paper, everything was fine. I have to say, though, that this was NOT an issue with the optical mouse I'd been using -- which is probably why I glossed over that part of the instructions.
Mar 05, 2011 | Kensington PocketMouse 72214
With no earlier damage to the usb port or mouse receiver to blame or trigger, the usb receiver of my Microsoft Wireless Mobile Mouse 3500 has become physically STUCK in the usb port and will not pull out!!...
the inside of a USB socket has 2 pins facing backward on the narrow side edges, i suspect these are somehow protruding in and catching on the USB device plugged in.
you could try to push the device in as far as it will go then wiggle side to side to push these pins outward while gently pulling.... if that doesn't work, try a thin hard strip of something (old credit card might be thin enough) cut it to the height of a USB plug and insert it down one side, then the other.
metal will also work and is perfectly fine to use (only down the narrow edges, not top or bottom) and can be made from a tin can lid or similar but be very careful of sharp edges if using metal, i suggest folding the bit you'll hold.... the biggest problem might be getting past the USB device plugged in as it normally overhangs the socket by at least a few millimeters at best, the finished tool should have a working area of 4mm X about 10mm insertion with enough "excess handle" to provide the force to insert.
notice the narrow edge of this USB socket and how the pin faces toward the back, you need to push those out. https://showmecables-static.scdn3.secure.raxcdn.com/media/catalog/product/cache/image/700x460/e9c3970ab036de70892d86c6d221abfe/u/s/usb-a-female-solder-connector-1.jpg
Sep 04, 2017 | Microsoft Wireless Optical Notebook Mouse...
The mouse and connector in the USB are lighting up and the mouse wheel and buttons work but the pointer will not move.
try to push and hold the synchronize button (or connect button) on bottom of mouse. Also make sure that batteries are new.
Oct 04, 2010 | Microsoft Wireless Mobile Mouse 3000
I have an hp wireless mouse, and it doesn´t work!! Tried everything...
Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this could help you a lot..:-) Thanks..
Dec 27, 2009 | HP Wireless Optical Mouse
I just got a hp optical wireless mouse and reciever,product no. is gm323aa,I checked the batteries,changed usb ports,pushed button on reciever alone and at the same time as the button on the...
make sure u installed your mouse properly...
also make sure that your usb point is correct....
make sure that the mouse u purchased is working....
Oct 04, 2009 | HP GM323AA Mouse
My new GE 98812 ergonomic wireless mini mouse isn't working anymore. It was very simple to set up for the first time last night (right after I bought it), but today it won't connect at all, even though the...
on the bottom of the GE wireless mouse there is a connect button make sure to push it one time then on the usb there is a connect circle hold it as if you were going to pinch it sounds dumb but I was just having the same problem and I read one of the solution fixes and it said to push connect button on back of mouse and also push it on the usb where it says connect even though the one that you push on the usb stick isn't a button but it is sensed once held with pointer finger and thumb hope this better describes it to fix it
Sep 30, 2009 | GE Wireless Optical Mouse
Resetting a wireless mouse
the usb connection and the mouse should have a button both need to be pushed usually the usb connector first then the mouse, or shut down the computer then restart. let me know if this helps.
Mar 31, 2009 | Logitech Cordless Mouse
Can not get the usb connector out of the mouse
I used a paring knife to try pulling the usb out of the mouse while pushing the button. On the 3rd side it must have straightened it out or pushed it in to place and to my surprise it slid right out. It has been working perfectly ever since. I really do like that little mouse.
Thank you for your concern. Barbara
Aug 30, 2008 | Innovera Wireless Optical Mouse,...
MS wireless notebook mouse 3000 not working?
A friend of mine brought me this problem with exactly the same problem. here is what I found. The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
Jul 08, 2008 | Microsoft Wireless Notebook Optical Mouse...
MICROSOFT WIRELESS MOUSE FOR LAPTOP DOESN'T WORK
There's also a connect button on the USB connector. Plug the connector in and press the connect button underneath until the light flashes. Release the button and click the connect button on the mouse until the USB light is steady.
May 16, 2008 | Targus PAKP003U Keyboard
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
