Question about Minolta Maxxum 400si 35mm SLR Camera
Mode Button Inoperable
I cannot switch the mode. The button does not seem to work.
  • 41 Answers
In most battery opperated, fim cameras, the buttons are usually composed of a plastic outer, the part you press, and underneath that button is a thin piece of angled plastic that keeps the button from depressing when you aren't touching it. That thin piece of plastic usually isn't very sturdy and can and had a tendency to break in half making it impossible to get a battery reaction. If you trust yourself with a small screw driver and have a good memory of what you take appart, you can replace this piece yourself. Any camera shop will have the piece you need. Other than that, you'll need some super glue to secure it and you should have a refurbished Mode button~!
Good Luck and I hope you're up taking photos soon!
Olivia~*
Posted on Dec 01, 2008
Htc one sv stuck in safe mode volume buttons inoperable
Turn off the device. Remove the battery, hold the power button down for 5 to 10 seconds. Reinstall the battery, this should reset the device back to normal. Hope this helps.
Jul 16, 2014 | HTC One SV
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
Oct 10, 2012 | Logitech Radio Communications
Timer switch mode is inoperable. no lights in timer setting, the lg ld450eal model operates continously. please advise how to program the 2 hour or 4 hour timer
With the Dehumidifier switch on, pressing the Timer Button should changed between 2hr and 4hr mode.
If this is what you're doing and it isn't lighting the LED nextto the 2hr and 4hr can you confirm what setting you have for the humidity?
Jun 25, 2011 | LG LHD45EL Dehumidifier
Hi, I have a Canon Powershot A700 digital camera and I am facing a problem with it. The 'Mode Switch' button, which changes the mode from Shoot/Record mode to Play/View mode is not working....
If you have the manual for this camera turn to page 15.
This tells you how to switch between Shooting Mode and Playback Mode.
This is achieved simply by pressing the DISP button.
This button is located below and to the left of the FUNC/SET button.
Pressing DISP repeatedly toggles between Shooting Mode and Playback Mode.
I would suggest you try these steps with your Mode Switch in both positions alternately.
May 20, 2011 | Canon PowerShot A700 Digital Camera
Panasonic DMC-TZ1 operates in Playback mode only
The position from the dial wheel is not corresponding with the electrical position. If you can do it by yourself you can adjust it and tighten the midscrew from the dialwheel
Regards, Rob NL
Apr 20, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Mode button unresponsive in my 2006 dodge dakota radio.
After sitting all day in the parking lot at work, I started the truck to go home and everything seemed back to normal. There must be some sort of time related reset. I have not tried pushing the MODE button again and probably won't until I need to.
Nov 04, 2008 | 2006 Dodge Dakota
ERROR: INSTALL TONER
Toner Empty Message If a Toner Empty Message is Still Displayed After a New Print Cartridge Has Been Installed, Enter the Tech Mode and Perform a Manual Reset CAUTION: Make sure to follow this solution carefully as incorrect settings made in the Tech mode can cause the machine to become inoperable. The Tech mode is intended to be used by service and support personnel only.
Before performing this solution, make sure a new Xerox PE220 SmartKit Print Cartridge has been installed into the machine. Other print cartridges are not compatible with the machine and a manual reset should not be attempted.
If necessary, see the Related Items below for additional information on ordering supplies, consumables, and parts.
To enter the Tech mode and perform a manual reset:
  1. Enter the Tech mode:
    1. Press the [Menu] button on the Control Panel.
    2. Press [#], [1], [9], [3], [4] using the numeric keypad. 'Tech' will be displayed on the Display Screen.
  2. Press the [Menu] button until 'Data Setup' is displayed.
  3. Press the [Enter] button on the Control Panel.
  4. Press the [Left] or [Right] arrow button on the Control Panel until 'Clear Counts' is displayed.
  5. Press the [Enter] button.
  6. Press [1], [9], [3], [4] using the numeric keypad.
  7. Press the [Enter] button.
  8. Press the [Left] or [Right] arrow button until 'Used Toner Cnt' is displayed.
  9. Press the [Enter] button.
  10. Power OFF the printer using the power switch on the rear, right side of the printer.
  11. Wait 30 seconds and then power ON the printer
Aug 28, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Ink absober full
Service - mode in which you can perform service operations with the buttons printer. To switch the printer Canon MP-series in the “Service” mode you:
1) Turn off the printer.
2) Press and hold the button lifting / resume printing.
3) Press and hold the button printer.
4) Release the button lifting / resume printing.
5) Double-click restoration / print.
6) Release button printer.
after that time will be flashing green LED (flashing time depends on the printer model), then it will go steadily and the printer will become the “Service” mode.
Low-Level - work intended for low-level operations with EEPROM printer, in this mode MPTool works with the printer. To switch the printer MP-Series Low-Level regime should:
1) Turn off the printer on the network.
2) Press and hold the button.
3) Add a printer to a network.
4) Click lifting / resume printing.
5) Release button.
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
Jun 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Acqua Indiglo Digital Watch
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
-AP
Dec 04, 2007 | Watches
Minolta Maxxum 400si 35mm SLR Camera Logo
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
