Question about Pentax IQZoom 160 35mm Point and Shoot Camera
Pentax IQZoom 160
The word HI is blinking and the camera is frozen with the zoom out and the flash out. Tried taking batteries out and turning off, but it does not respond. What's the problem?
  • 1 more comment
  • Anonymous Dec 18, 2007
    I have the same problem with the word HI blinking and camera is frozen. Taking battery out and replacing does not solve problem.Automatically rewinding the film and removing it will unfreeze the camera but you will loose any photos that were on the roll of film. I cannot find my owners manual to see if this problem is addressed.
  • Anonymous May 01, 2008
    Frozen with HI flashing
  • kgonter Nov 05, 2008
    I took a picture like I have many times before and the camera froze and started flashing HI. I replaced the battery but it didn't help.
svenby
  • 66 Answers
SOURCE: pentax optio m20 .. on-off immdly
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Posted on May 30, 2008
mail541
  • 58 Answers
SOURCE: Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Posted on Jan 21, 2009
SOURCE: AV flashing in LCD of camera whn zoom attached
I found on some lenses you need to go into the menu , select settings and change av appurature setting to 2 instead of 1 .
Posted on Mar 04, 2009
SOURCE: AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Posted on Mar 17, 2009
pontelemon
  • 538 Answers
SOURCE: camera needs fixing
Camera needs Zoom Flex.
Part is NLA from 2003
Posted on Apr 02, 2009
I need a user Manual for ESPIO 160 Pentax camera
The ESPIO 160 is called the IQZoom 160 in some parts of the world. You may download a copy of the IQZoom 160 manual here.
May 31, 2012 | Pentax ESPIO 160 QD 35mm Film Camera
I have acquired a Pentax IQZoom 700 as a gift. I'm not sure what kind of batteries it takes though, as it did not come with a manual. Can anyone help me?
The IQ-Zoom 700 uses two 3V Lithium batteries (CR-123A or DL-123A). You can order a new manual for $8 from Pentax: http://www.pentaximaging.com/support/manuals-and-literature/ . Use the drop down menus to select your model.
I hope this helps.
Aug 17, 2010 | Pentax IQZoom 105WR 35mm Point and Shoot...
I have a Pentax IQZoom 160 and it has error code U3 when I turn it on. The flash and zoom try to deploy several times but only the flash comes out.
If the 'U' disappears when the zoom lever is moved your camera is ready to use. It may be defective if it comes up often.
(IQZoom 160 manual p.49)
Dec 04, 2009 | Pentax IQZoom 160 Date 35mm Point and...
Camera is DEAD...batteries ok How do I get film out
Go to the camera store and buy an old fashion film change bag so you can take the film out of the camera and roll the film back on the spool. The bag is light proof.
Aug 10, 2009 | Pentax IQZoom 160 35mm Point and Shoot...
Camera needs fixing
Mar 16, 2009 | Pentax IQZoom EZY-R 35mm Point and Shoot...
Can't take pictures.
Guest,
pentax codes are in repair manuals, not instruction manuals. H3 indicates shutter failure. this means anything from the flex circuit on the zoom barrel ( inside ) to the shutter itself. camera needs repaired.
Aug 18, 2008 | Pentax IQZoom 200 35mm Point and Shoot...
Problems with camera. Help please.
THE CAMERA ZOOMED OUT COMPLETELY AND WHEN I SWITCHED OFF IT REMAINS AS IT IS , AFTER PUTTING BATTERY & ROLL IT SHOWING ( f 1 ) & AFTER SOMTIME ( f 2 ) AND AGAIN IT WILL SHOWING ( f 1 ) ON INDICATOR.
Nov 08, 2007 | Pentax IQZoom 200 35mm Point and Shoot...
What does HI or H1 mean?
This is a zoom error code - the flexible circuit going to the shutter in the barrel is probably worn out. It'll have to go to a repair shop.
Nov 27, 2006 | Pentax IQZoom EZY-R 35mm Point and Shoot...
Loaded film, but won't work and a "3" is flashing.
The IQ Zoom cameras are designed to display error codes (E0, E2, E9, E10, E1A, E37, E90, HL, H4, H5, etc.) when something goes wrong internally with one of the mechanisms or electronic components. These diagnostic displays help to determine where the problem is. When you see an error code, ask a qualified PENTAX repair technician to examine the camera. For information on a specific error code, call Pentax customer service department toll-free at 1-800-877-0155, Monday-Friday 7:30am-4:30pm, Mountain Standard Time.
Oct 04, 2005 | Pentax IQZoom EZY-R 35mm Point and Shoot...
Pentax IQZoom 160 35mm Point and Shoot Camera Logo
78 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
