Irratic behaviour of the switch network
We have more then 50 switches with more then 200 computers. suddenly the network has started behaving iratically. all the network gets jammed and stops accessing to the central switch.When one switch is removed from the network it starts working fine. but swich may be any of the 50 switch.wat may be reason.  1) I could not renew the antivirus, is it possible due to virus. 2)My switches are more then 4 years old .Is the problem related to the old switches. 3) the correct method of detecting the problem?
  • 3 Answers
I'm assuming that the network topology didn't suddenly change so the number of switches probably isn't an issue. I've been a net tech for (unnamed organization) at the enterprise level (Thousands of switches, hundreds of sites, each with dedicated routers, and too many network clients to count). I have seen problems like this numerous times and it is ALMOST ALWAYS caused by a 'loop', or a broadcasting virus (like sasser, netsky, and numerous others). A 'loop' will cause what I like to call 'Digital Feedback'. If your organization has a way to detect broadcast storms (packet sniffer, or a hardware-based network analyzer), you should be able to ID the affected/infected switches/computers. If the problem came about suddenly, I would look for a loop first and, since you mentioned that you can't update your AV definitions, a virus is also something to watch for (an infection is usually traceable with a packet sniffer such as WireShark (previously named Ethereal)). If you could give a general topology layout of your network, I may be able to be more helpful. As far as the 7 switch limit... I think this limit is based on each switch's maximum limit on the number of MAC address (per port or per switch) though, 7 is a VERY high number of 'inline' switches (if they are indeed 'chained' together or connected 'in series').
Posted on Dec 29, 2009
  • 70 Answers
Well 1 can tell you that if I remember right with cisco networking the maximum number of swiches possible between two hosts in a LAN network is 7.
Try to imagine a line with 2 pc at the end points. You can put maximum 7 swiches between them or expect problems.
I suggest you to try to make a current network map if you don't have one already.
Than do some counting between points just like the way your routing protocol is managing the packets route and see how many swiches you hit.
You can read about a very similar kind of incident with brand new CISCO equipement over here.
Maybe the problem's root is something else, but what you wrote was giving me this idea first to think of.
Hope I gave you an idea.
Posted on Nov 26, 2008
My blower works intermittently-once it starts it works
May 10, 2010 | 1999 Ford Escort
My computers seem to have become somehow linked by the KVM switch
The GCS632U is just one KVM switch. But if you're going to check it out, it has actually two separate connections.
It will just switch once you toggle from one computer to another.
Try to power cycle the KVM switch.
1. Shut off both computers.
2. Disconnect the KVM switch from the computers. (make sure that not even a single cable is connected to the computer, even the audio).
3. Leave it disconnected for 10 minutes.
4. Reconnect the KVM and boot up the XP first.
5. Boot up the Vista, try to toggle from one computer to another.
6. LASTLY, shut off the Vista and see if same problem will occur.
If you get the same problem, then you need to contact IOGEAR and have them RMA the device. Because this is the first time that I heard of this problem.
Thank you and good luck!
Jan 25, 2010 | IOGear GCS632U 2-port KVM Switch
Hello...when you move the speed switch on it nothing happens...its like there is no electric hooked up at all. The model is the 6qt Profess series
It sounds like you may have an issue with your main board. If this is faulty you can have irratic behaviour or none what so ever. You can visually inspect this by first removing the power. Then Remove the rear access panel. After this is removed you can see the main board. Inspect it for any burned marks or wires. Also you can smell for any burning as this can prove useful. Part number for the board is W10119326. Hope this helps.
Nov 20, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Motherboard ga945pl-ds3, when I turn off power suply, I can´t start computer (culer works, I have power, but procesor don´t want to start), but after that computers works. I must reset bios (that...
PSU could also be playing up and not giving correct voltage to motherboard - check outgoing voltage from PSU with voltmeter and check product standards for that model... If ok then it could be the motherboard itself - all it takes is a capacitor or transistor/logic gate(switch) and it will start behaving unusual...
May 05, 2017 | Gigabyte Computers & Internet
Aspire 2930z with windows XP restrat and switch on problems
the battery may be damagedm try taking the battery out and then re-start the computer to see how it behaves.
Jun 01, 2009 | Acer Aspire 3610 Notebook
Switch starts switching back and forth between computers itself
There are no firmware updates for the GCS62 also the KVM appears to not have a firmware upgrade port. If the KVM is auto-switching have you tried hitting the ESC key or Space Bar? That should stop the auto switching.
Feb 12, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Indecit dishwasher not circulating water
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Mar 04, 2008 | Dishwashers
Suddenly quit and won't start.
Could be a processor failure, but try changing the cmos battery first on the mobo and locate 'JBAT1' terminal on mobo and put jumper across pins 2-3 then back to pins 1-2 and try starting up again.
Jan 09, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
449 people viewed this question
David Payne
David Payne
