Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
My SonyGrand Wega lamp is inserted properly yet sets off sensor
Red led flashes 3 times indicating lamp is not screwed in properly. No picture No sound and I would love to watch some football this Thanksgiving.
  • 505 Answers
3 blink error = lamp door.
if the lamp door melts and deforms, you have a clogged fan that cools the lamp. then the door won't hit the lamp door switch. the right way to fix is to replace the lamp door and the fan, but you could clean out the fan and just hard wire the lamp door switch to think its closed to fix the problem. just remember that the switch is there so you can't open the door while the lamp is on and burn your eyes with the UV. you can put a jumper wire in the connector that hooks to the wire to the lamp door switch to bypass. cleaning the fan is easy as long as no smoke or grease is mixed with the dust. remove power to the set, remove the back and front as well as the lamp door. take compressed air and spin the fan up to blow the dust out the fan, it will blow straight out the lamp door hopefully. when you look into the back of the tv, the fan will be just above where the lamp is, on top of the engine. it is a non-typical scrirocco type fan.
Posted on Dec 07, 2008
My 50" Sony Wega kdf50E2000
the lamp door cover is not secured properly or the lamp is not inserted correctly. Thats what the 3 blinks is indicating.
Aug 23, 2011 | Sony KDF-50E2000 50" HDTV
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
What does 3 flashing red lights mean on aa 55in sony wega? The TV won't turn on and i just replaced the bulb
make sure lamp cover (first plastic cover that was removed from tv cabinet to replace lamp) is fixed back properly because 3 times red light flashing indicates that lamp cover is not in its place.
Thanks.
Oct 21, 2010 | Sony Televison & Video
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Kdf-50a11e blink 3 time on red no images no sond when i start it the green lead blink many time then the red led blink 3 time and puse then 3 time
Three flashes indicates either the lamp is not seated correctly or the lamp door is not on properly. I bet its the later of the 2 as THE most common issue is the lamp door has warped because of excess heat building up in the lamp cage. If this is the case follow the link I am providing as you are in luck as Sony is paying for those repairs. Please take a moment to rate my answer...Thanks
http://esupport.sony.com/US/perl/news-item.pl?&news_id=261&mdl=KDF50WE655
May 18, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Red light flashing
DO NOT under any circumstances touch the red wire inside the set. This cable connects to the picture tube and carrys 33,000V and can cause injury. The 3 blinks are a diagnostic code that indicate the defective circuit. Please confirm the model number as KV-36FS120 and I'll look up the code.
There is no Lamp door if this is the KV model mentioned above as this is a CRT based set not a projection set.
Please confirm the model number so I can get you a proper solution.
Thanks,
Dan
Sep 11, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Grand wega kdf-55wf655, won't power on and led flashes 3 times
Make sure lamp cover is placed properly and securely after lamp replacement.
3 blinks of LED shows lamp door is still open or not closed properly.
Jul 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
3 times flash shows error in Lamp Cover. Please check lamp cover at back of tv and set it properly, if you removed it.
Let me know if
have query.
bye.
Sep 08, 2008 | Sony KDS-R50XBR1 50" HDTV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
570 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
