Question about Mercury Electronics CyberPix S-550V Digital Camera
I dont no how to turn my camera on and dont no if it needs batteries or has to be charged and cannot find charger.
Push the button on top of the camera to the left of the dial, once your camera comes on, push the menu button, and hold down the larger button on the top right to take a picture.You might want to set the dial on top to the A (auto mode) as this works best. to turn the camera of, hold down the button on the top left. Hope this helps
Posted on Feb 05, 2009
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
I dont know what is going on with my camera, but i i charged the battery and now it wont turn on. i dont think i over charged the batt. because it wasnt on for that long. PLEASE RESPOND SOON i have a...
Rechargeable batteries can and do just die without warning.Sometimes the charger does so as well. The charger automatically prevents overcharging though.
Realistically, all you can do at short notice is to try another freshly charged NB-6L battery. if a camera shop has a display model they might allow you to try their battery in your camera, or more likely, your freshly charged battery in their camera.
Jul 22, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I dont know how to charge it it didnt come with a charger
The 5022 is a camera, not a battery charger. It uses standard AAA batteries. If you use rechargeable batteries, you must charge them outside the camera using a separate battery charger.
Dec 25, 2010 | Vivitar ViviCam 5022 Digital Camera
I have charged my camera but it will not stay on when turned on
you dont have explain exactly the problem.. if the problem turn on and off istantly this is shure a lens problem and you mst change the lens. if the camera turn on one two 3 minute and than turn off its probably that the camera dont charge the batterie. if the camera dont charge you can bypass the problem. you can buy on ebay a external charger for your batterie. if you search on ebay international seller you can find charger and batterie to a very good price. its possible to find two batterie and one charger to 10 sterl. so you have new batteries and a external charger. external charger is better as charge the battery in the camera. why i is nott so difficult that the batterie explode and ruine the camera. with a external charger this is not possible why you can ruine the charger that have a low cost but not the camera. i hope that i have help you. its possible that the camera dont charge its possible that the batterie dont mantain the charge.. its possible if the camera go on and go out directly that this is a lens error.. sorry foer my english
Aug 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
Put battery in charger and red light just flashes. put battery in camera and nothing happens
This is usually because the battery is faulty and needs to be replaced. Just to be sure, turn off the charger and then back on again. Put the battery back on charge to see if the error is repeated. If so you will need to obtain a replacement battery. Unfortunately, this does happen with a fair number of rechargeable NiMh and Lion batteries and many are no where near there expected lifecycle of 1000 recahrges.
Oct 13, 2009 | Casio Exilim EX-Z77 Digital Camera
Can't charge the battery
I didn't have the time to find out what was the problem cause i needed the camera immediately so i bought a new battery and a new charger.Thanks for the help!!
Aug 07, 2009 | Olympus FE-220 Digital Camera
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Dec 26, 2008 | Casio Exilim EX-Z77 Digital Camera
Olympus FE-280 Digital Camera problem
First the obvious, Is your charger actualy charging? Have you tried another Battery?
Sometimes the charger led turns green, when it actualy never charged the battery.
Jiggle the battery around to make sure it is seated securely. If in doubt find a friend with a Volt meter (VOM ) and check that the battery voltage is 3.7v to 4.0v when fully charged.
Assuming that you now have a fully charged battery. it's time for a little house cleaning. Use a Q-tip and Isopropal alcohol .99 cents a bottle. (Not Rubbing, it contains lanolin).
Gently clean the contacts on the charger and the battery. You dont need a lot. A little dab'l do ya. You can also clean the contacts on the charger with a pencil eraser if they look a little corroded.
Now it gets a little more fun. Look down inside the camera battery compartment and make sure the spring contacts are sticking up far enough to contact the battery, also make sure the battery eject spring is not bent and interfering with the contacts or the battery.
If you feel confident, gently, very gently, clean the contacts in the camera.
Only wipe towards the center once or twice. If you wipe the other way, you will have
cotton fibers wrapped around the contacts. not good ! If you do not feel confident cleaning inside the battery bay, Dont!....... send it to Olympus. I hope that does the trick for you. Nice taste in cameras by the way. Sumthin
Mar 31, 2008 | Olympus FE-280 Digital Camera
Battery or charger?
battery. call tech support and they will replace.
Mar 25, 2008 | Casio Exilim EX-Z60 6MP Digital Camera...
Mercury Electronics CyberPix S-550V Digital Camera Logo
Top Mercury Electronics Cameras Experts
Marvin
Marvin
Are you a Mercury Electronics Camera Expert? Answer questions, earn points and help others
