Question about Aardvark Direct Pro Q10 (bundle) External Sound System
Aardvark pro q-10
Do I have to attach the monitor outputs of the pr0 q-10 to an external mixer to hear what is being played on the computer or should the pro q-10 play through the computer "audio out"? I have a gigabyte ga-p35-ds3r/s3r board (realtek audio onboard)
Yes, you have to connect the monitor outs to a mixer (or directly to your monitors) to hear. It is a totally separate sound card than what is coming out of your audio out port. Anyway, you'll get much better sound quality from the monitor outs.
Posted on Dec 12, 2008
I can't hear the sound from my PC when I'm using the mixer. Its hooked up to both the computer and the speakers, but when I'm recording in pro-tools 11 I can't hear any of my playback. I have to bounc
hello. Im not too familiar with Protools (mainly because its a headache right out of the box), but MY understanding is that Protools won't recognize a lot of external audio devices. (such as behringer)
however..if you are able to record and 'see' the audio there, just not hear it, there might still be a solution, & seeing as how i never used protools, it still might just work.
First of all:
if you're using the UCA-200 external usb box connected with rca cables, then my solution SHOULD work, as it is what i did to get mine to finally do the same thing.
#1) you will need to pick up (x2) RCA-1/4 jack adapters . (radioshack, about $2 each)
#2) insert a red and white rca cable in the RIGHT side of the Mixer's CD/Tape out .....the other end of the rca cables will go into the UCA-200 INPUT.
#3) with 2 more cables in the OUTPUTs of the UCA-200, put the rca-1/4 jack adapters on both cables, insert them back into the Mixer inputs 9/10 (in the analog 1/4 instrument inputs)
#4) adjust volumes accordingly, make sure channel 9/10 isn't muted, headphone volume is up, etc..
.......if that didn't do the trick, then you will need to go into the Audio Settings menu on your computer..(or protools) and change the default playback device to your mixer (probably named Generic USB or something similar)
I really hope this helps somewhat, because i remember going through the same thing & it took a looong time to find the correct awnser.
best of luck!
*also*
check for any updated drivers for your mixer! (I personally recommend you do a Google search for Asio4all drivers, they're pretty good)
if your awnser is A), i would suggest going into your computer's Audio Settings menu, and select the mixer as your default playback device.
Nov 23, 2013 | Behringer XENYX 2442FX Mixer
Os10 mac drivers for aardvark q10 pro
can download the drivers here...
http://www.michaelchagnon.com/aardvark/download.html
Jun 29, 2008 | Aardvark Direct Pro Q10 (bundle) External...
I have a snap back delay when I try and record using my m-audio and protools. I can hear a slight delay in my headphones to what I'm actually playing. How do i get rid of this?
Hi emmastevens
what you are hearing is latency(delay) in the electronics, software, and maybe your computer is producing some problems also. Have you tried to monitor yourself direct from a mixer before you feed the signal into the MBox.
regards
Graeme
Apr 08, 2008 | Audio Players & Recorders
Aardvark Direct Pro 24/96 Audio effects problem
Checkout your sound mixer setting in windows control panel (if you have windows) or in "Preference" or "Advance setting" tabe in adobe audition software
Check your connecting cables have appropriate jacks
Mar 19, 2008 | Aardvark Direct Pro 24/96 Sound Card
Aardvark Direct Pro Q10 wont intall with windows xp
I NEED A AARDVARK, DIRECT PRO Q10 INTERFACE (CONNECTOR) HOST TO BUY. CAN YOU HELP ME FIND ONE?
THANK YOU,
BRIAN MCBEAN
Feb 17, 2008 | Aardvark Direct Pro Q10 (bundle) External...
Smapls missing in kernal32
Go to C:\Program Files\Aardvark\ Aarkthk.dll and remove this file. It is an old file from win98 that didn't get removed when installing on winXP. Restart computer and you're good to go.
Dec 07, 2007 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark Problem
You are looking for: "6' length, custom 25 pin shielded cable" Try on shopping.com or Amazon...: http://www.shopping.com/xFS?KW=custom+25+pin+shielded+cable&FD=0 You will find it there.. Good Luck. K.
Sep 10, 2005 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark Direct Pro Q10 (bundle) External Sound System Logo
102 people viewed this question
Top Aardvark Computers & Internet Experts
David Payne
David Payne
Are you an Aardvark Computer and Internet Expert? Answer questions, earn points and help others
