Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Blurry copies Did everything Xerox suggested on Website including changing maintenance kit. What to do?
    President:
  • 2,072 Answers
On the drum drive motor there is an encoder, it gets contaminated by the silicon oil in the maintenance kit. Removing it and cleaning it will alcohol will normally resolve that problem.
Sometimes that encoder will need to be replaced. But if you need further instructions, ask, I will let you know what to do.
Posted on Nov 26, 2008
Driver
I would try to download a new driver from the Xerox website and set that one to default.
Mar 09, 2012 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Apr 07, 2009 | Xerox Phaser 8560MFP Laser Printer
Blurry images
Yeah , that is most likely the problem. If ou remove the right side cover , there is an encoder on the end of the drum motor shaft, It becomes contaminated with the silicon from the maintenance kit.
Fixing it requires you to pop the encoder off and flush it well with alcohol. It is unlikely is has failed, but when dirty is causes the drum to turn at the wrong speed.
Mar 27, 2009 | Xerox Phaser 8550/DP Thermal Printer
Blurry Copies on Xerox WorkCentre C2424
There are three typical reasons for fuzzy text
1. Y-axis drum rotation problem.
2. Wrong drum temperature.
3. X-axis movement problem.
Sometimes the y-axis encoder will get oil inside and confuse the sensors, causing fuzzy/blurry print.
Most likely the drum assembly will need replaced.
Dec 03, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Blurry copies on Workcentre C2424. Tried the solution regarding the encoder on the drive/drum motor. However, now the unit is back together but showing two codes: 04,024.4X & 07, 007.40. Not copying but...
Both are related to the process control signal. That is the motor assembly on the right side of the machine that is responcible for the movement of the maintenance kit.
You may have something disconnected from it. Or the sensor on the maintenance lift plate is disconnected or knocked out of position. But those coded both relate to the process control motor and gear chain. That is the motor on the right side, toward the front with the gear cluster attached.
Reset counter on Xerox Phaser 8200
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Oct 05, 2008 | Xerox Phaser 8200DP Thermal Printer
PHASER 8400
There is an encoder on the drum drive motor that picks up lubricant from the maintenance kit. It may simply need cleaned, if cleaning doesnt work, it will need to be replaced.
Xerox has parts lists on the xerox.com site for that product if you need to locate it.
Sep 09, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Jul 11, 2008 | Xerox Office Equipment & Supplies
Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Jan 15, 2008 | Xerox Phaser 8500/DN Printer
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
77 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
