Question about Ricoh Aficio 1013 All-In-One Laser Printer
Printer says "load paper"
We have a Ricoh aficio 1013 and it says LOAD PAPER. We have selected the correct tray, (8.5X11) and it has about half inch of paper in it. We have opened and shut all access doors and powered on and off to see if that would "clear " it. What can it be?
    Problem Solver:
  • 9 Answers
If you pull the paper tray all the way out and lift the tray slightly in the front it will pull out from the machine. look inside the ope area and you will see that the switch that registers paper is probably fallen out of place. Just super glue it back in and make sure the connector is reconnected.
Posted on Dec 19, 2008
My Ricoh Aficio printer 1018 is telling me to "load paper 8 1/2 * 11" on the screen whenever i try to print anything from any computer in the network because i am using RJ 45 instead of normal...
Make sure you have 8.5" x 11" paper loaded into at least one of the paper trays, and make sure it's loaded in the same orientation as the page you are trying to print. Also check to be sure the copier is set to recognize 8.5" x 11" paper -- it may be set for a different size. On the main Copy screen, if you select the paper tray, does it show 8.5" x 11"?
Feb 03, 2011 | Ricoh Aficio 1018 Printer
How to prink on cardstock on Ricoh Aficio CL2000N
To print on cardstock:
- Load the cardstock paper in the paper tray and make sure the fences are snug but not too tight.
- Press Menu.
- Scroll down to find Paper Input and select it.
- Select Paper Type.
- Select Tray 1.
- Scroll to find "cardstock" on the list and select it.
You'll also have to set your print driver for cardstock or auto select, because if the print driver shows plain paper and the printer shows cardstock paper, you'll get a mismatch error.
Aug 08, 2010 | Ricoh Aficio CL2000N Laser Printer
The 8 1/2 x 11 paper tray will not open - it is not jammed with paper as the print still prints, but we cannot dislodge the tray.
You need to forcibly open the tray, that's the only way. It could be the feed roller assy is gettin hung up.
Dec 23, 2009 | Ricoh Aficio 1013 All-In-One Laser Printer
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
Aficio Copier 1013 light on to load paper ( paper is loaded)
Check the paper end sensor, remove the tray, look inside of opening, at the top toward the right side, make sure there is an arm sticking down, wires are connected and the sensor is in place. Most common problem is the arm is dislocated or sensor out of position, See graphic 91009d0.jpg
Apr 15, 2009 | Ricoh Aficio 1013F Copier
How to print 17 inch paper on Ricoh AP 3800 C
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
Feb 13, 2009 | Ricoh Aficio 1013F Copier
Paper pick-up for by-pass tray won't work
OPEN BACK AND LOOK FOR A SMALL PIECE OF PAPER FROM PRINT JOBS PAST THAT MAY HAVE JAMMED ...FOLLOW THE PAPER PRINT TRAIL, CHANCES ARE YOU WILL FIND SOMTHING BLOCKING THE PATHWAY!
Dec 07, 2008 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio 1013 All-In-One Laser Printer Logo
163 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
