Question about Acer Computers & Internet
Operating system not found
When i switch my laptop on it says "
intel UNDI, PXE-2.0 (build082) Intel corporation VIA Rhine 11 Fast Ethernet Adaptor v2.35 (2004/06/011
PXE-E61: Media test failure, check cable
PXE-MOF: Exiting Intel PXE ROM.
operating system not found.
I have absolutley no idea what this means. I put the recovery disc in and nothing happened. do you think it is beyond repair
  • Acerious Feb 12, 2009
    it doesn't work. mine has Error no partition at the top
    Sergeant:
  • 177 Answers
First enter your bios setup by pressing F2 when your computer starts. Find the section which sets the boot device order. Change the first boot device to CDROM. Save the settings and exit bios. Now put your recovery CD in cdrom drive and see if it runs.
Let me know if it does not work
Posted on Nov 26, 2008
Hi i just switch my laptop aspire 6920 on and its start beeping and then its show me Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Atheros AR8121/AR8113 PCIE Ethernet...
enter to bios setup and remove Ethernet controller from boot sequence or make it last on the list. and about operating system not found if you already use your system without problem then reinstall the system from a cd .
Jul 23, 2011 | Acer Aspire 6920 Notebook PC
My laptop is not working and just keeps comin up with this messsege and i lookedup online and tried all the things it said to do on thr BOOT Settings, but it just keeps coming up with the messege:- Intel...
The computer is booting up using the ethernet. Usually this boot up is used on one of the workstations of a Network. The computer should boot up on the hard drive. Its just that the network is priority over the hard drive. For you to change this you must configure the Boot options on the BIOS.
1. Go to the BIOS settings 2. Go to anything that associates with Boot Options 3. Make the CD/DVD ROM be the first boot device 4. Make the Hard drive be the second boot device 5. Make other Boot Devices retain to 3rd and so forth Save the changes and restart the computer 6. If all fails make sure that the hard drive is detected on BIOS if not 7. Try to disconnect the hard drive and put it back in Go to the BIOS see if it is detected 8. If not replace the Hard drive
Jul 19, 2011 | Computers & Internet
Upon start up my Dell Mini keeps showing a code stating " intel UNDI. PXE.2.1 ( BUILD082) For Realtek RTL8101E/8102E PCI Ethernet controller v1.08(080408) PXE-E61: Media test faliure. check...
You computer is trying to boot from the LAN port (Ethernet).
Go into the BIOS by pressing either the F2 or the Del key. Check and make sure the hard drive is recognised by the system as with it saying "Operating system not found" does not sound good and could mean a hardware failure.
If it is seen by the BIOS check the boot order, change it to the HDD as the first boot device.
Regards.
Dec 15, 2010 | Dell Inspiron Mini 10 Notebook
I keep getting intel undi pxe-2.1(build 0892) copyright (c) 1997-2000 intel corporation for realtek rtl8100/8101e fast ethernet network adapter v1.02 (060510) pxe-e61 media test failure check cable...
Your laptop is trying to boot via LAN(network). Possible the HDD is not being detected by your system that is why it could not boot to windows. Try to boot up without the ethernet (your internet cable) connected to it and see if it works. If not, you may have a bad HDD.
Hope this helps.
Dec 19, 2009 | Toshiba Satellite A135-S2276 Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
I own a Hi-Grade Via 14'' (VE8569)Notebook and until last night haven't had any problems with it - but for some reason when I turning it on, I am getting a black screen with the following message: Intel...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty.
First - re-seat the hard disk and reboot the computer. if this does not work then reboot and go to the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Next - to determine if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external hard drive and you cannot open the various folders and files, this confirm the hard drive is faulty.
The hard drive needs to be replaces in the laptop and Windows installed and the laptop's device drivers and your programs etc to get a working laptop again.
Oct 29, 2009 | Computers & Internet
How do i repair my pc it gives a message that says Intel UNDI, PXE-2.0 (build 082) Copy Right (1997,1998,1999)Intel Corporation VIA Rhine II Fast Ethernet Adapter V2.43 (2005/12/15) PXE - E61: Media test...
Dear,
If you are using PC then make sure that Boot from PXE Rom is disable and boot from hard disk drive is enabled. Check your BIOS setting for configure it.
Regards,
Rakesh Kumar
Network Support Engineer
Apr 07, 2009 | Compaq Computers & Internet
Booting problems with acer laptop - no operating system found??
PXE (pronounce Pixie) is an agent used to boot on to the network.
It's using the DHCP protocol to localise a server where the image of the OS is located
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
This can be caused if the hard drive is missing, unplugged or corrupt, or simply by not having the boot order configured correctly.
When you start your laptops, press F2 repeatedly until you enter the bios set up, navigate to the boot order and make sure that the hard drive (sometimes listed as HDD....) at the top of the list.
Hope this helps, let me know if you need anymore help.
Jan 27, 2009 | HP Pavilion dv6000z Notebook
Argh girlfriend spilled hair gel on my laptop
thats ethernet card realtek
did you check to see hard drive is securely in tack
saying can't find os
you may need to do a new install let me know
if you took apart you made have caused hard drive to become lose
Jan 17, 2009 | Acer Aspire 3610 Notebook
well ur msg clearly states operating system not found.
for this u hav to install ur OS again.
As ur sister has a branded machine u must hav got a Operating System CD-ROM with it for backup.(in ur case it must be vista)
if u hav the cdrom then turn ur system on just put the cdrom into the drive and let it do what follows.
It may ask u abt where to install ur OS(means which partition)
just select the desired partition and many other simple questions which u can easily answer incase u hav any problem I am always there.
Hitesh
+919923888524
Jul 08, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
291 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
