Question about Panasonic X70 Earbud Hands Free Headset
X70 In India
I have brought my brothers panasonic x70 phone to India, now its not working here and it is locked, how to unlock the phone here to use it with Indian sim card
0 characters
1 Points
Restriction code for Nokia 6020
Note : Please try unlocking your Nokia 6020 mobile phone only once using the steps given below with the Nokia 6020 unlock code you get from our unlocking tool. If it does not work, do not try again as it may get your Nokia 6020 permanently locked. Do not enter any wrong unlock codes on your Nokia 6020 mobile phone. If you enter over a certain amount of wrong unlock codes on your mobile phone, your Nokia 6020 phone may get permanently locked and sometimes become unusable.
1 - Switch on your Nokia 6020 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6020.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6020 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6020 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6020
Mar 16, 2014 | Nokia Handsfree For 6020, 6101, 6102...
Free Unlock Code
What is your Nokia model?It's IMEI number,network and country it is locked now?You can use unlock code to unlock it from network lock if it is locked to network.Free unlock code can be easily get for Nokia DCT phones.Get free Unlock code for Nokia DCT phones from If your Nokia phone is latest model phone free unlock code is not possible to get you need to pay to get the unlock code. Get the unlock code from the site and get free unlocking instructions from the site and unlock it step by step.
May 09, 2013 | Nokia BH-100 Bluetooth Headset
Insert sim
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or third party unlocking service provider like, and remove the network lock. Once unlocked it will work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine with your previous Nokia mobile and also the phone gives the same error message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
May 01, 2013 | Cellet Blackberry T-mobile Curve 9360...
Unlocking a Nokia 100
I forgot my call barring service password for my Nokia 1661-2
Apr 12, 2013 | Nokia 100
Nokia 6162 codes
1. Switch your 6120C off and then on again using the power button on top of the phone. A "Lock Code" screen will appear if the phone is locked.
2. Enter your lock code using the number buttons. The default code is "12345." If you enter the wrong code five times in a row, the phone will ignore all entries for five minutes, after which you can try again. See Tips for more information.
3. Press down the "Scroll" key. The phone will unlock with the right code, enabling you to make phone calls and send messages.
Aug 19, 2012 | Nokia 6161 6162 6650 fold 7205 Intrigue...
Restriction code
Nokia 2730 c (classic) 2730c 1b is same...You can get the restriction code from the site and get the Free Unlocking instructions at here
and Unlock it step by step....
May 01, 2012 | Nokia 2730c-1b_nokus_blk Classic Unlocked...
My phone is locked to o2 i need a nck code
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
Nov 16, 2009 | Sony Ericsson Mobile Bluetooth Car Kit...
Forgot my phone security code for nokia nseries?
this code works for most nokia models.. hope it works for you. it shows the current security code in use, i guess the one you forgot..good luck!
Apr 28, 2009 | Nokia Consumer Headset
Headsets Logo
20 people viewed this question
Top Panasonic Headsets Experts
Lawrence Oravetz
J Smith
Level 1 Expert
Are you a Panasonic Headset Expert? Answer questions, earn points and help others
