My Asus Z96F cmos don´t recognize my keyboard. I want to reset my cmos but I don´t know how.
  • Howard Lester May 11, 2010
    Are you saying that it does't see your built in keyboard? Or are you trying to use an external keyboard with your laptop?.
  • 153 Answers
Just remove the cmos battery leave for a minute and put it back. cheers.
Posted on Nov 27, 2008
Keyboard when i type it does not work. but when i press esc then it work
Hi
I would try and reset the default settings in CMOS
press esc or f1 etc to access cmos settings
select load setup defaults and save and exit
this will reboot
then retest the keyboard
cheers
Jun 03, 2015 | ASUS Computers & Internet
Asus a6r bios reset
You can try to remove the CMOS battery.
Dec 24, 2012 | ASUS A6Rp-AP067M Notebook
Asus P5NT motherboard - will not boot to bios
The voltage output onto the three main rails as you put it is 12 volts and 5 volts. As you say that there is no beeping, you must be getting power lights and fan spin up. This would indicate a failed graphics card. I may am only going on the information you have supplied. Although if there is no lights or fans it may be a failed psu. You also don't identify your PSU. if you have the one that came with the tower, it isn't surprising.
Sep 05, 2012 | ASUS P5NT Deluxe Motherboard and Intel...
My motherboard 945gct-m/1333 v3.0 doesn't recognize the PS2 keyboard and USB mouse.
Hello Nelson, most likely you may need a new motherboard. But here are some thing you may try before considering on buying one,
  1. try replacing a new motherboard battery.
  2. reset you bios. locate jumper cmos battery.
let me know your progress.
Nov 24, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I don't know my security code
if you are referring to a password protected hard drive
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Hope this helps you
Sep 13, 2011 | Computers & Internet
How do I replace the cmos battery in a ASUS Eee PC 900AH?
i think the cmos battery is under the keyboard. if it is there should be two screws under the laptop that will have the simbol of a keyboard, remove these and take out the keyboard. hope this helps
Jul 20, 2010 | ASUS Eee PC 900 PC Notebook
My notebook S96F bios don´t recognize my keyboard
remove the battery and power cord then open the system find the battery on the motherboard remove it carefully let it set out for 10 min. then put the battery back on the motherboard put the system back together replace battery and power cord cmos should be reset
Nov 26, 2008 | ASUS M5N Combo Notebook
Asus P4B Motherboard
Press DEL to enter setup and set Reset to Defaults in Exit menu. If you have USB keyboard, make sure you enable Legacy USB and USB keyboard settings, save and exit and reboot.
Aug 04, 2008 | Computers & Internet
Keyboard stays on
I would first Reset the CMOS... do this by switching the jumper pin cap from 2-3 to 1-2 then give it power/and immediately power off.. then reset jumper cap position to original spot... the jumper can be located usually near the CMOS battery.
Jun 01, 2008 | ASUS A8N-SLI Motherboard
ASUS P5N-SLI Motherboard
Maybe bad memory what type did you buy?
Aug 28, 2007 | ASUS P5N-E SLI Motherboard
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
