Question about Yamaha Electrical Supplies
Low voltage Voltage is about 98v with no load. It will increase if I advance engine speed by hand. When I put it under load, voltage drops but engine speed doesn't increase. Again, if I increase engine speed by hand, voltage will rise.
Welcome.
I am the owner of the generator YAMAHA EF 600. During the last exit on the nature of the generator produces a higher voltage. Instead of 220 volts produces 450 I have spoiled all the light bulbs in the lamps.
Changed item12 7H5-87105-01-00 RECTIFIER ASSEMBLY . It did not help.
Please help to solve this problem
Posted on Sep 26, 2014
I have a brand new Nothernstar belt driven generator, I set the engine speed with no load to produce 61.5Hrz but the voltage remains low at 103VAC. When I switch on some load (an AC Unit) the frequency drops to 60.5Hrz but the voltage stays at 103 VAC.
Posted on Jul 19, 2013
    President:
  • Yamaha Master
  • 1,388 Answers
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Posted on Nov 30, 2008
Our 2007 Ford Freestyle 3.0V6 shows B1318 code, also scanner shows low battery voltage module. Car shuts off.Please help what to do to fix?
Which module ?
B1318 Battery Voltage Low Audio Control Module REFER to Section 414-00 . B1318 Battery Voltage Low DSM REFER to Section 414-00 . B1318 Battery Voltage Low DVD Player REFER to Section 414-00 . B1318 Battery Voltage Low Instrument Cluster REFER to Section 414-00 . B1318 Battery Voltage Low RCM REFER to Section 414-00 . B1318 Battery Voltage Low Satellite Radio Receiver REFER to Section 414-00 . B1318 Battery Voltage Low SJB REFER to Section 414-00 .
According to this charging system isn't working correctly ! This is a computer controlled charging system .
Principles of Operation
The powertrain control module (PCM) controlled charging system determines the optimal voltage setpoint for the charging system and communicates this information to the voltage regulator. This system is unique in that it has 2 unidirectional communication lines between the PCM and the generator/regulator. Both of these communication lines are pulse-width modulated (PWM). The generator communication (GEN COM) line communicates the desired setpoint from the PCM to the voltage regulator. The generator monitor (GEN MON) line communicates the generator load and error conditions to the PCM. The third pin on the voltage regulator, the A circuit pin, is a dedicated battery voltage sense line.
The charging system voltage is controlled by the PCM. The generator charges the battery and at the same time supplies power for all of the electrical loads that are required. The battery is more effectively charged with a higher voltage when the battery is cold and a lower voltage when the battery is warm. The PCM is able to adjust the charging voltage according to the battery temperature by using a signal from the intake air temperature (IAT) sensor. This means the voltage setpoint is calculated by the PCM and communicated to the regulator by a communication link.
The PCM simultaneously controls and monitors the output of the generator. When the current consumption is high or the battery is discharged (the PCM recognizes this and increases the output of the generator to accommodate), the system is also able to increase the idle speed to increase the charge.
To minimize the engine drag when starting the engine, the PCM does not allow the generator to produce any output until the engine has started. The PCM then progressively increases the output of the generator.
The PCM turns the charging system warning indicator off after the engine is started and illuminates it under fault conditions (when the generator is not generating the correct amount of current with the engine running). The charging system warning indicator is also illuminated by the PCM whenever the key is ON with the engine OFF.
This is a System 4 charging system, which uses the GEN MON and GEN COM lines to control and monitor the charging system through the PCM. System 4 charging systems are virtually identical in design and therefore, share the same diagnostics. The circuit numbers and colors may be different, but the functions are the same.
Jun 30, 2017 | Ford Cars & Trucks
2000 buick regal. Losing fuel pump voltage
http://www.bbbind.com/free_tsb.html free wiring diagrams ! Enter vehicle info. year , make , model an engine size . Under system click on engine ,then under subsystem click on fuel controls . Then click the search button , then click blue link .The 7th diagram down shows two fuel pump relays , This I have not seen before ! One is speed cont. relay an the other is just fuel pump relay ? The speed control one has a resistor in the electrical circuit . That is way your droping voltage .
Fuel Pump Electrical Circuit Diagnosis (VIN K)
Fuel Pump Electrical Circuit Diagnosis (VIN 1)
The PCM alters fuel pump speed by energizing the fuel pump speed control relay. Under normal conditions, the fuel pump speed control relay is energized. The applied voltage to the fuel pump is controlled by a resistor assembly. When higher fuel volume is required due to increased engine load, MAP sensor value over 90 kPa the PCM de-energizes the fuel pump speed control relay circuit. The increased voltage to the in-tank fuel pump allows a higher volume of fuel to be delivered to the fuel rail. The PCM also compensates for low system voltage by energizing the fuel pump speed control relay.
Have it check for codes !
Did DTC P0230 or DTC 1260 set?
Go to DTC P0230 Fuel Pump Relay Control Circuit or DTC P1260 Fuel Pump Speed Relay Control Circuit
Go to Step 3
May 05, 2017 | Buick Regal Cars & Trucks
AC voltage is 275vac on the powermate generator model # PM069250......engine speed is 3750 rpm (max is 3600 rpm)......how do i lower the speed and the 275vac to a nominal 240vac output.There is no expert...
On the engines carb. is a governor rod should connect to the front case of the engine. This rod should have an adjustment to slow the engine speed. BUT,,, are you reading the generator unloaded or without any thing plunged into it? Once you have the generator loaded with a device, the voltage should drop to a constant 240vac. 150 rpms should not make that big a difference on the voltage output, and if running under load the RPM's should drop also..
Sep 04, 2011 | Acabion Helix Motorcycles
My generator only puts out 89 volts.
I need a model number for your ENGINE not the whole generator. I believe this is a case of the engine not running fast enough. I.e governor adjustment will be necessary. Respond with an Engine model number and I will stll you how to adjust the governor speed.
This is GENERIC but the Governor arm has a spring that connects to a speed plate. The speed plate has a stand off screw and nut used for speed adjustment and a center nut for securing the speed plate in a fixed position. The Steps are to slightly loosen the center nut and the locking nut on the speed adjustment screw. Start the unit with a meter reading output power voltage (use extension wire for meter) Then turn the speed increase screw in to increase speed. When you reach 122-123 VAC stop. The reason you adjust it to 122-123 VAC is because voltage will drop as the generator provides power loads
Tighten the screw lock nut while running if possible and tighten the center nut on the speed plate to secure it in place. Check voltage again.
If you generator is running at normal speed and you have low voltage output... most of the time the Capacitor is failing. If the capacitor is failing the magnetic field in the armature and stator collapse under above average loads causing HUGE voltage swings.
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Briggs & Stratton Electrical Supplies
Hello, my Briggs & Stratton generator, PP5000, Intec, 8 hp, Model 202412, type 0167E1, has lower power output, 180 Volts in stead of 220-230 Volts. Any idea where I should look ? Engine is 8 years...
Hi and welcome to FixYa. I am Kelly
Usually when you have a lower voltage output that is yet above 150 VAC the problem is as simple as the engine is no longer running at full speed. This could be caused by binding carb or governor linkages but more often than not the Governor adjustment screw has backed off over time causing the engine to gradually slow so the output voltage drops. The user does not notice it so much until the output drops more than 15% and you notice dim lights... slower running equipment etc.
Look for a circular plate / governor speed plate near the base of the governor lever but off to one side that has a spring that attaches to the governor lower end of the governor. There should be a screw with a locking nut. Loosen the nut and turn the adjusting screw clockwise to increase engine speed. (You may have to barely loosen the pivot nut on the governor speed control adjustment plate to make the speed adjustment.... tighten when done with speed adjusment) Watch your output voltage and adjust the voltage to 225 VAC with NO LOAD. The voltage will drop as loads are added. Make sure to tighten the lock nut on the adjusting screw or in a matter of an hour you will have low voltage again from engine speed dropping. What ever you do.... DO NOT adjust the governor arm base attach point where it attaches to the engine.
Just so you know a weakened governor spring can cause the speed drop also. If the speed keeps dropping with extended use, you may have to change the spring that goes from the lower end of the governor arm to the governor speed adjustment plate.
Kelly
Apr 20, 2011 | Briggs & Stratton 3,250 Watt 6.5 Hp...
I have a coleman 6000. It runs for a whileand when I load it up it trips off.
Make sure the governor is working properly. When you put a load on it the engine should increase in speed slightly. Make sure the engine is running at the correct speed 3600 rpm. Try plugging in an item that draws less power such as a electric drill and see how the generator behaves. Also make sure the engine runs smooth while not under any load. Check the voltage from the outlet to make sure it is putting out 132 volts not under load.
Mar 14, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
Volt gage jumping arround less notice when under load
I would first suggest using a volt /amp meter and test the voltage from the large wire off the back of the Alternator. You will need a second person to help feather the throttle to change the engine speed. You should see a steady increase in voltage from 12.6 to 14.5V when the idle is increased. If the voltage jumps around on the meter then chances are you have a bad voltage regulator in the Alternator and need to replace it. If the voltage is normal and doesn't bounce around then you have a faulty gauge in the dash.
Jul 31, 2010 | 1995 Chrysler LeBaron
1998 k1500 5.7l 105a alternator. replaced
Now change the sulfated batery for a new one.
Vitally
Sep 09, 2009 | 1998 Chevrolet K1500
Volt gage drops when not accelerating, replaced battery and altenator, its running worse now
What are the voltage readings?
Voltage may drop when idling and a larger voltage drop can be present when a large load (amp draw)is present on the alt.
A low charged battery is a large load.
Operating accessories is a large load.
A slow spinning (idling) alt will not put out it's max output.
This would be normal.
We like to see.....above 12.7V at idle....max 15V.......
.......and a min of 13.5V to a max of 15V at higher engine speed.
If you are with-in this.......don't worry about it.
Aug 27, 2009 | 1992 Buick Century
Portable generator low voltage
85 volts represents residual voltage. It is possible that your unit sat for an extended period and lost it's magnetism or the excitation system failed under load. check your manual for a procedure to "flash the field". If that is not successful, e-mail me and I'll tell you how to trouble shoot the failure.
Jan 02, 2009 | Novelty Manufacturing Older Than Dirt...
Electrical Supplies Logo
1,211 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
