Home | Pentax | Optio S50 Digital Camera | Sony cybershot DSC...
Pentax Optio S50 Digital Camera
Problem for Pentax Optio S50 Digital Camera
Sony cybershot DSC-S50(not focusing)
By DiverDave on Jan 08, 2007
hi, i turned my camera on after a long time of not using it and it turned on normally, the camera seems to be stuck somehow it doesnt focus or zoom in/out and the numbers (E:61:10) are flashing on the top right hand side of the LCD screen, is there any way of fixing this? any help would be very greatly appreciated,
thanks, Dave
Same Problem
Mar 10, 2009
-   hi i have sony dcr dvd106e. it has problem no E:60:00
any body tell me its solition. -   Guest
Dec 15, 2008
-   Thank you , guys. I had the same problem with my T-30. After 2 whacks on the lense barrel , it works normally now.
Thanks again and I really appreciate. -   Howardhj99
Sep 26, 2008
-   i have sony DSC-T9 (Lens inside the system). Unfortunately it got slipped from my hand. After that i received error E:61:00.Service centre asked me to replace whole lens barrel, but it's costly.
so please reply me with any other method, which i can do on my own.
-   yuvrajsinghp
Sep 06, 2008
-   In meiner Kamera von Sony Cyber-Shot DSC-T10 blinkt im Display der Fehler E:61:10
Es funktioniert auch keine Displaybeleuchtung
Und es lassen sich keine Bilder mehr machen.
Ich hoffe sie können mir weiter helfen.
Vielen Dank-   Guest
Aug 30, 2008
-   i had same problem (E:61:10)..-   singh_shiris
Best Solution
posted on Apr 10, 2007
Very Helpful)
gfoGG
Rank: Apprentice
Rating: 97%, 20 votes
Belive or not, the smacking method works !
I have just tried on my TRV-22 and the zoom is working fine now ! I should have tried it before my daughter's birthday, which is now very badly recorded (no zoom or image adjust), but I didn't, too bad!
P.S. My smack wasn't very strong. Just a couple of light hits near the lens barrel.
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #2
Very Helpful)
Gbeck
Rank: Apprentice
Rating: 96%, 37 votes
After reading other solutions on this same error message, I decided to follow the advice of one that did not require taking it to the shop and having it repaired. I hit the barrell against the table with two good whacks, and it the error message disappeared. The zoom now works and so does my auto focus and manual focus. Problem solved, believe it or not. I held my breath because I was scared I would break it, but now it's fixed.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #3
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Turn the camera off and give it two smacks and WA-LA the error message is gone.
I started off with two pretty light smacks on the back of the camera and worked my way up to what I would consider two medium hits with a power down in between each double hit. It only took three attempts...but I was being pretty gentle in the beggining.
Solution #4
posted on May 27, 2009
Very Helpful)
abbyjones135
Rank: Apprentice
Rating: 100%, 7 votes
seriously smacking it really does work.LOL Just a few slight smacks near the lens barrel and voila it works now. Thanks to the ***** slapper it works lol
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #5
posted on Apr 03, 2009
Very Helpful)
alrigth
Rank: Apprentice
Rating: 100%, 3 votes
yes guys got the same problem on my sony DCR-DVD- 101. It really worried me, but having read your smacked solutions, at first i was hesitant to do it you know how expensive this gadgets are. But no choice i have to try something as i need it by the folowing day. Smacked the cam n my table againts the back of the battery pack, and it really worked. I guess sony company will do something about this, its the same case that i stock my dvd cam for a long period of time then i decided to use it again, that's when the error appeared E:60:00 . Just hang on guys and do some sony smacking.... I really works Thanks a lot guys
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #6
posted on Mar 14, 2009
Very Helpful)
tweetylei_21
Rank: Apprentice
Rating: 100%, 4 votes
I had an E61.00 error on my Sony DSC-P100 camera. I tried the bumping on hard surface . I bumped it bottom edge down at the lens end about five times with increasing hardness of bump and then turning off and on again after each try. After about five times E: 61.00 error had gone. I can hardly believe it.
It really did work.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #7
posted on Dec 16, 2008
Very Helpful)
duceduce4
Rank: Apprentice
Rating: 100%, 1 votes
I had the same problem (E61:10) and I used a Multi-Purpose Duster (compressed air) to clean the mechanisms.  Apparently that error just means there is a jam in the focusing gears and once I did this cleaning my camera worked like a charm!
Good luck
Comments:
Dec 16, 2008
- I used compressed air to clean the mechanisms, just blasted it with some air & PRESTO!  it works like new*
Good luck
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #8
posted on Jul 29, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
First, I took to repair and they told me I would cost 70% of a new camera, so I better get another one.
Then, started smackingand it Does work! First I got a 61:10 message, after some smacks I got to 61:00 and finnaly to the camera working perfectly.
Solution #9
posted on Jun 13, 2009
Helpful)
mook32
Rank: Apprentice
Rating: 92%, 3 votes
Same problem with a T7, but since the lens is completely internal the "bang it" technique did not seem to work very well. So I opened up the casing and re-seated the lens assembly and that solved the problem. Its pretty easy to do, 8 screws, remove the memory stick and battery, leave the battery door open and flip the front cover up and off. Then you have full access to the lens assembly. Just be careful of the flex wires. Hope this helps!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #10
posted on Oct 26, 2008
Helpful)
pdj54
Rank: Apprentice
Rating: 88%, 2 votes
I have a sSONY Mavica MVC FB71 still camera and had the same error code.. E:60:10 ..a few sharp raps aon my computer desk put it back in order..I contacted SONY Support and they wanted $205 to repair..Nice savings for me!
Was this helpful?
Yes
No
Solution #11
posted on Jan 26, 2008
Helpful)
smack it
Rank: Apprentice
Ok guys, ...... copy and pasted my reply from another site.........
Lol, Ah man, what a joke. Typical Sony bollocks. I'm sick and tired of this company. Always the same deal. They are always whining. Finally threatened to cause a stink in the shop and I guarranteed them they wouldn't be selling many cameras from that shop that day. They kept it for like 3 days and when I got it back it was fine. Now, 3 wks later I have the same problem again.
They make great cameras but their service sux the big one. Always have. Anything that goes wrong takes like 2 to 3 months. This is precisely why I bought a Dell computer. At least I have some guy show up the next business day if there's a problem. Will never buy a Sony computer again. Their computer service is even worse.
Edit///.......
Ok, fixed the sucker with some good whacks. Here is a support site that goes over the problems with this message........
http://www.fixya.com/support/t129748-sony_cybershot_dsc_s50_not_focusing
Same deal, give it a few good whacks and you're back in the black.
Unbelievable. Too funny.
Was this helpful?
Yes
No
Solution #12
posted on Sep 21, 2008
Somewhat Helpful)
iqarus
Rank: Apprentice
Rating: 75%, 1 votes
Sony DSC-707 had this problem after taking it apart - solution was to remove right-side panel of lens barrel (including hot shoe plates), and re-seat the visible ribbon cables. Note that some have a brown lever bar that needs to be lifted up first, and then replaced. Also note some look like they have this bar, but don't need to be raised!
On the same model - if your flash isn't working, there's a buried ribbon cable that might be at fault. Careful though - I think mine was partly torn, and I ripped it the rest of the way off being too aggressive. Not a biggie since it wasn't working anyway....
Was this helpful?
Yes
No
Solution #13
posted on Nov 01, 2009
Not Rated)
cherrysherry
Rank: Apprentice
Rating: 0%, 0 votes
OMGG itt workkkss! thee wackingg methodd realllyy reallyy workss att firstt i starrtt too wackk it mann hardd thenn myy freindss weree thinkkingg imm crazyy wackingg at myy cameraa.calose urr cameraa thenn wackk it in the backk mann hard then openn itt and zommm outt/press thee zomm buttonn andd taaddaa itt workkss...omgg thxxx plll
Was this helpful?
Yes
No
Solution #14
posted on Oct 31, 2009
Not Rated)
Blurpo
Rank: Apprentice
Rating: 0%, 0 votes
I tried the take it apart and clean it .. No good.. ( please don't attempt unless you have another camera. :-)
Place a towel on a hard surface, and grasp the camera in the palm of your hand with the display screen facing downward and smack... one medium strength... all was fine and now I am using like I did when it was new.....
Was this helpful?
Yes
No
Solution #15
posted on Sep 05, 2009
Not Rated)
tvdb2003
Rank: Apprentice
Rating: 0%, 0 votes
I just experienced the same issue. E:61, no focus, lens stuck. I reset the camera, no change. Then I followed the others here and smacked the lens barrel twice with two fingers. It worked. Incredible. Thanks!
Was this helpful?
Yes
No
Solution #16
posted on Jul 17, 2009
Not Rated)
mconnormail
Rank: Apprentice
Rating: 0%, 0 votes
Boss handed me a sony dsc-p10 cyber shot camera
wouldn't focus or open. Two firm wacks later. you guessed it
it works great! thanks
Was this helpful?
Yes
No
Solution #17
posted on Oct 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
worked here too dsc p200
Solution #18
posted on Sep 02, 2007
Not Rated)
achillesbane
Rank: Apprentice
Rating: 0%, 0 votes
I have a DCR-HC32 Sony HandyCam...there was a E:61:10 message, the focus and zoom failed to work...i.e. the image was blurry
With the unit turned off, I gave it one firm smack against the palm of my hand (smacked the back of the unit where the battery pack and optical lens/eyepiece are located).
When I turned the unit back on it worked perfectly.
Was this helpful?
Yes
No
Solution #19
posted on Sep 01, 2007
Not Rated)
Abhi2711
Rank: Apprentice
Rating: 0%, 0 votes
This method of whacking really works.
I was trying my gently tapping it on the sides and back on my DSC-p52 but then got frustrated soon. The last option i hit it hard on my book and BOOM i am good
Happy zoomin...
abhishek
Was this helpful?
Yes
No
Solution #20
posted on Aug 26, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Read this solution on a site, and thought it must be a con. When I found the 3rd site with this on, I thought I would give it ago. 2 firmish smacks into the palm of my hand on the lens barrel, not so hard that it was likely to do more damage, turned it on and it works!
Still a bit sceptical - don't know how long it will last for
Solution #21
posted on Aug 24, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Mine got worse when smaking it (The sound of some mechanicel zome linse i presume). But smacking it on the back side solved the problem. THAT's a winner guesz. Thanks.
Lars
Solution #22
posted on Jul 22, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have dsc-T7
sometimes the shots are fuzzy and Cyan color is present on all objects borders, like alot of abberations.
the solution is:
turn the camera Off, shake it in your hand hardly and turn on again.
VOILA! Its working again.
I tried to disassemble it and check what is wrong but I cant find anything for this moment
Popular Solutions for Pentax Optio S50 Digital
Questions and Unsolved Problems for Pentax Optio S50 Digital
Do you recommend Pentax Optio S50 Digital Camera?
Answer
Answer
My camrea, won't turn on. I brought it to school, and my friend asked if she could take picture, but... (More)
Answer
the focus on the Optio s50 does not work. THe flash does not activate either
Answer
power source problem camera turns on the shuts down immediately
Answer
I thought the camera was broke. Went looking on this site this morning. I first pressed the reset... (More)
Answer
When I try to format the Memory card it gives the foll message: card did not format. What could be... (More)
9 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 22, 2008
sony cybershot DSC-P30 error message E:61:10 (zoom focus doesn't)
suggested fix, reset, alternatively smack camera lightly on knee
Comment by Guest, posted on May 13, 2008
me too, sony dsc-t70. e:61.10. I was dubious about trying such a primitive solution, we call this method the 'american wrench' in ireland but it worked after about 4 light taps on a hard surface. I think some sand or something blocked the lens
Comment by Guest, posted on May 12, 2008
My DCRDVD108 is not focusing and I get Error message E:61:11. I at first had E:61:10. help!
Comment by dcausey5, posted on Apr 16, 2008
error code E61:10 flashing, zoom is stuck, won't take a picture and lcd screen is very blury
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pentax Optio S50 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
