Question about Gateway /Creative SoundBlaster Sound Card
Gateway Computer 710X Speakers are crackling/popping
I have changed speakers, speaker connection wire, updated sound card drivers, and the crackling/popping still persists. My Gateway 710X sound card is Sound Blaster II Audio with IEEE 1394 Sound Card.
Do you have any suggestions on how to get the crackiling and popping repaired?
Thanks for any help.
  • 96 Answers
It sounds as if the card itself may be physically bad. or you may have a microphone connected/something in your mic jack and you are picking up noise.
Posted on Nov 27, 2008
Built- in speakers crackling sound
1. This can happen if you have played something with a lot of bass and the speakers are now damaged. The speakers might need replacing.
2. It could be that the speakers aren't that good in the first place.
3. Try updating the drivers on your computer for the speakers
4. There could be a connection problem within the laptop where the wires are not properly inserted into the motherboard.
Hope this helps.
Aug 14, 2013 | Samsung R540 Laptop
Just moved and my speakers are not working. The green wire is plugged into. Thecomputer - am I missing something else? We have power in the speakers
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 12, 2011 | Gateway Edison Computer Speakers
Crackling and hissing sound either on speakers or when using headphones. Speakers work fine on another laptop. Only happens on my Gateway 5260 desktop.
It's probably related to the drivers. Go to Creative Labs website and download the latest driver package for the specific card and OS you're using. They'll walk you through how to identify the exact model of the card if you're unsure. Hope this helps.
Nov 26, 2010 | Gateway /Creative SoundBlaster Sound Card
Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones,  then replace the speakers. Must be a lose wire or something of that nature.
Jul 27, 2009 | Dell Studio 1737 Laptop
Sound only playing out of one speaker in Windows XP
Go into Sound Settings under control panel. There should be a left-right audio control setting in there.
If that doesn't work, try updating the sound driver for your computer.
Jun 01, 2009 | Intel Motherboard
Crackling and popping sounds in surround sound speakers
Could be your head unit or the connection to the speaker may be bad. Also if the wire to the speakers in your ceiling is bare and touching any ground it would interfere. Start by checking connections by playing something and messing with wires. Listen for a difference. Next check by putting the wires that power those speakers in a known working output and listen for different quality
Apr 04, 2017 | SpeakerCraft 8" 150W In-Ceiling Speaker...
Crackling Speakers
That because maybe due to your itunes player which the installation got error..please try another player other than Itune or play it in windows media player or some other player which you think good player.
Or try reinstall your player or update it.
if this not resolve the issue, then verify the connection of your sound card maybe got grounded to other components making the sound crackle..Or you may try attached a grounding wire from your stuff directed to the ground or attached in any metal that is connected to the ground to eliminate noise.
please tell me what ever result for further analysis
Feb 10, 2009 | HP Computers & Internet
Gateway Computer Speakers are crackling/popping
yes it could be going out on you, if you have empty slot on mainboard or another computer you can try it on,then you can confirm if it is broke or not. hope this helps, glen
Nov 26, 2008 | Gateway /Creative SoundBlaster Sound Card
Speakers Make a Very Loud Noise that Increases
try uninstalling drivers and reinstall them.
also remove latest M.S update as some update cause more trouble than they are worth
May 21, 2008 | Audio Players & Recorders
Gateway /Creative SoundBlaster Sound Card Logo
179 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
