Question about Toshiba Satellite M35X-S161 Notebook
I am working on a Toshiba Satellite M35X-161. when i press the power button, it lights up, fans and hdd spin up. and then it kills the power after about 3 seconds. i have tried re-seating the RAM and HDD. can u think of anything to try other then replacing the RAM? i am trying to avoid spending money.
  • jw98520182 Nov 26, 2008
    same problem. no change.
  • JDTec
    JDTec May 11, 2010
    Take your battery ou and power up. Let me know what results.
  • Toshiba Master
  • 4,338 Answers
Have you checked the DC jack where the power adapter plugs in. With the adapter plugged in, wiggle it and see if you get movement. Hold it upward and turn your unit on, if the power stays on, then it is the DC connector on the motherboard that is loose.
If your fan is working correctly, then check your ram. But experience has shown me that an issue like this is usually motherboard related.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 26, 2008
Hdd light does not come on during power up on toshiba l555d-s7005
If the screen stays black it means there is an issue with BIOS. It should load before the HDD ever does. Mother board issue or monitor issue.
Dec 29, 2017 | Toshiba Satellite L555D-S7005 Notebook
I have Toshiba satellite M35X-S163 when press power cpu fan start and hdd run for 2-3 seconds then gose off nothing on the screen internal or external ; in addition no battary charging . battary and the...
in the pic that is not m35x that is m30 ... if u have m35x ...and no display open the laptop near the power jack there is maxiam ic ... jsut heat that ic.. hope that will work .. if not let me know thanks
Oct 08, 2010 | Toshiba Satellite M35X-S163 Notebook
I have a Toshiba M35X-S109 and it won't boot. The power light will come one, I can hear something (like a fan) for 1-2 sec and then nothing. Any ideas?
do a hard reset, it might work.
take out the charger and the battery, press and hold the power button for about 20-30 secs. put back everything inside. and now see if it works.
Apr 29, 2010 | Toshiba Satellite M35X-S109 Notebook
After fixing power jack problem secreen will not lit
toshiba satellite M35X-S111
After solving the jack problem.
when I click on the start button I hear the fan voise but there is nothing on the moniter and no sound.
When I remove the connection between the start button and the mother board and put it again it works two times and then the problem started again.
The computer may work random at sometimes.
Is the problem in the small board and the cable which between the start button and the mother board ?
If yes how to purchase it
Dec 12, 2009 | Toshiba Satellite M35X-S111 Notebook
Wont start or boot up
I had the same problem and found that disconnecting the power lead and repositioning the ribbon cable from the on switch did the job after about 5 attempts
Aug 13, 2008 | Toshiba Satellite M30X Notebook
My M35X-S111 keeps shutting down
More than likely it is overheating you can buy a can of compressed air and blow it out if you dont have a compressor that should be done at least every 6 months
Aug 06, 2008 | Toshiba Satellite M35X-S111 Notebook
PROBLEM WITH MY SATELLITE M35X-S111
Check to see if your Display is bad or Video is bad..
To Do This....
Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
May 19, 2008 | Toshiba Satellite M35X-S111 Notebook
M35X does not boot up
You know this model has a warranty extension till the last of November. If I were you, I'd be sendinng it in quick!!!
They are very good at getting your machine back in 2 or 3 days.
Good luck
Nov 06, 2007 | Toshiba Satellite M35X-S349 Notebook
Toshiba M35X-S109 Doesnt Start
you may have a faulty motherboard connection, but try connecting the power adapter in without the battery and see if it runs, then replace the battery back in the compartment.
Oct 15, 2007 | Toshiba Satellite M35X-S109 Notebook
Toshiba Satellite M35X-S161 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
