Question about ASUS M5N Combo Notebook
My notebook S96F bios don´t recognize my keyboard
I want to reset my cmos but I don´t know where I can find it and how I shall do it.
    Problem Solver:
  • 5 Answers
Remove the battery and power cord then open the system find the battery on the motherboard remove it carefully let it set out for 10 min. then put the battery back on the motherboard put the system back together replace battery and power cord cmos should be reset
Posted on Jul 22, 2009
Reset bios
Resetting the BIOS is hardware related you have remove the CMOS cell for atleast 30 mins. You need to remove the keyboard and its panel the CMOS cell is located rite underneath the keyboard.
Sep 19, 2013 | Acer Aspire 5610-4648 Notebook
Computer was locked
Resetting the CMOS password on an Acer Aspire laptop is much more difficult than resetting the password on a desktop.
Disassembly steps vary from model to model, but on most models, you'll have to take apart the computer to access the CMOS battery.
Don't take apart the notebook if you don't have experience disassembling PCs.
After turning off the computer and disconnecting the AC adapter, take out the battery (different from the CMOS battery).
All visible screws must then be removed from the bottom of the notebook.
Remove all components stored to their separate compartments on the base of the notebook.
Turn over and open the PC. Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible.
Remove the keyboard.
Remove the screws securing the monitor to the hinges, and then set the monitor aside.
Disconnect all visible cables connected to the motherboard; and then remove the screws from the top cover.
Remove the top cover to reveal the motherboard. Locate and then remove the CMOS battery. Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire.
Other Options
If removing the CMOS battery fails to clear the password, or if you dont feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password.
These special passwords were implemented to allow technicians to access locked computers. Not all models recognize backdoor passwords.
Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include BIOS, CMOS, phoenix and PHOENIX.
All of these passwords are case-sensitive.
Apr 22, 2013 | Acer Computers & Internet
How to unlock a computer
Is it an aspire ?
Other Options
Bios lockout
If their is no password on your BIOS boot into BIOS and go to "Reset to Factory Defaults". If their is a PW you don't know you will have to remove the screws and clips that hold the keyboard on. Pull the keyboard up and underneath you will see the CMOS battery which looks like a watch battery. Pull it out and leave it out for 30 minutes or longer to allow the capacitors to drain. replace the battery and the keyboard and you should be back to factory defaults for the BIOS.
Mar 08, 2012 | Acer Aspire Notebook PC
Acer travelmate 2700 bios password and where is the CMOS battry on the mother board
your bios battery is soldered into the mainboard, its under the keyboard, next to the modem board and the bios chip itself.
In order to get to the battery you would first have to dissasemble the laptop, remove the keyboard, power buttons, and the top of the machine. You may also have to remove the display if its holding the top of the cover in place.
Removing the battery is no guarantee of reseting the password. You need to study the bios chip and find out which pins of it you need to short in order to reset its memory. In some cases the password might be stored on another chip.
Oct 09, 2011 | Acer TravelMate 2700 Notebook
I don't know my security code
if you are referring to a password protected hard drive
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Hope this helps you
Sep 13, 2011 | Computers & Internet
My laptop keyboard not work at booting time
I would first try to reset the CMOS according to the manufacturer's instructions provided on the manual.
Try that, and please report back the results.
You might wonder what is CMOS?
Complementary metal oxide semiconductor (CMOS)
is a type of semi-conductor chip that holds data without requiring an external power source. In a personal computer (PC), CMOS holds the basic instructions the computer needs to initialize its hardware components and boot up. These settings are known as the basic input output settings (BIOS), also referred to as CMOS settings.
Steps to Reset CMOS - BIOS Setting.
Turn on your computer and press the key on your keyboard to enter the BIOS. This is typically the Del (delete) key. Pre-built systems from major manufacturers may use a function key such as F1, F2, or F10. Go to the last tab or page of your BIOS. Select an option similar to "restore factory settings". Save your changes and confirm your selection if necessary. This will often be combined with the process of exiting a BIOS. Some BIOS types may have this as a separate option such as "F10: Save Changes".
Please let me know if you have any further questions or concerns.
Thanks.
May 04, 2010 | HP Compaq Presario C500t Notebook
I want to reset bios
You need to open your laptop. Disconnect battery first, unscrew cover and look for the CMOS battery which have the same size of a dime. Remove the battery and return it after 10 seconds. The BIOS shall be reset.
Dec 07, 2009 | Toshiba Satellite Pro L300D-EZ1002X...
I neeed clear bios cmos and cmos run to my hp ze4315us
Restart system holding down f11 key till it beeps. Dont forget to backup your documents.
May 26, 2009 | HP Pavilion ze4315us Notebook
My Asus Z96F cmos don´t recognize my keyboard. I want to reset my cmos but I don´t know how.
Just remove the cmos battery leave for a minute and put it back. cheers.
Nov 26, 2008 | Computers & Internet
ASUS M5N Combo Notebook Logo
224 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
