High pilot I have this heater and the pilot light is to high when heater lights w/alot of orange glow---- when not lite the pilot light is lower but still has a orange glow at the tip. I know that the pilot should not be as high as it is by past use. Can you help me?
  • 27 Answers
Clean the pilot assy. poor gas/air mix
Posted on Nov 26, 2008
What is the flame sensor
The flame sensor is attached to the pilot light. It's down on the right side of the burner tray and usually has an orange wire attached.
The flame sensor lets the heater know that the pilot light has been lit and it's okay to open the main valve.
images?q=tbn:and9gcs_-csiy0xlxc4vgn5fxb5i4km7zxxkzfpham9qknrvchqj1v19hq
Mar 06, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
I can smell gas but heater will not ignite. Display shows that the heat is on. Thanks!
First of all, be careful while looking into the system when the gas comes on because it could unexpectedly ignite and burn you.
You listed this question in the Jandy Lite 2 Natural Gas Pilot Light Heater. If your heater is a pilot light heater then the pilot light needs to be lit so when the gas comes on it will ignite.
If your unit contains a thermal ignitor it should glow brightly when the gas starts. If it is glowing then it is probably not glowing brightly enough or not in the right place and therefore needs to be either replaced or repositioned. If it is not glowing then you should measure the voltage using a volt/ohm meter going to the ignitor. If it reads about 115 VAC then the ignitor is broken and needs to be replaced. If it reads much lower voltage then the board that supplies power to it probably has a problem on it. It may be a defective relay, bad solder joint or some other problem. I would first re-solder the relay connections to the board and see if that fixes it. Otherwise the board will need to be replaced.
If the unit has a spark ignitor and you hear a spark sound it may be too low power or the spark probe might be in the wrong place and therefore not delivering the spark to the fuel air mixture. If you don't hear the spark then you may have a bad relay or bad solder joint to it.
Please let me know how this works out. Thank you.
Sep 03, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot lite won't light
I believe your heater uses a" Glow plug" style igniter not a traditional pilot.This type takes a few minutes to lite. Be sure the correct pump is running,the gas valve is turned on, and the Bypass valve is at least 1/2 way closed.Also make sure you have at least 10 psi on the filter gauge.
Oct 08, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot lights but as soon as it ignites the blue flame turns orange - I'm assuming there is a leak? How do I test this?
could be blocked orfice , mix some water and washing up liqued in bowl make bubbles and brush this on the pilot joints bubbles up you have aleak
Jun 01, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Charm glow gas heater won't stay lit changed thermocouple and it worked for 2 days
Dust build up inside the pilot light burner assembly. A clean pilot makes noise and has a blue flame when it is burning. A dirty pilot has a quiet and smaller flame with an orange tip.
Oct 15, 2009 | Williams 2509612 Ceramic Mid-Size Heater
I have a Comfort Glow propane heater connected a 20lb tank. The pilot has a hard time staying lite but when I do get it lite ang turn the hearter on low it will shut off in a minute or in some cases 20...
If you have a pilot, you have a thermocouple. I would start with the thermocouple. The thermocouple is supposed to be heated by the piolet and to keep the pilot gas on. If it is faulty, the pilot will quit and the heater will not reignite until you light it again. Good luck...Lee
Sep 21, 2009 | Desa International Comfort Glow Infrared...
Pilot light stays on but burner doesnt ignite
usually the small opening on the burner that 'points' to the pilot light will get clogged with cleaning soap or spills. Look carefully (the burner may be very easy to remove for inspection. There should be a small hole on the side pointing toward the location of the pilot light. It will be lower down than the main burner openings. Clean it out with a wooden toothpick.
Jun 19, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Empire corcho ventless propane wall heater 15000 btu
LOL.... your fuel is not boiling.... the closer propane gets to its vaporization point (-44%F) the less vapor it produces. clean the snow off of the 100# or lay it on its side to give it more surface area for vaporization.
David Lawrence the propane dude
Oct 04, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
146 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
