Question about Brother MFC-465CN InkJet Printer
My Brother MFC 465-CN keeps saying "No paper fed"
The paper is correctly placed, doesn't want to feed it.
  • Anonymous Feb 19, 2009
    I have the same problem and tried the alcohol. still no work
    Champion:
  • 320 Answers
Try cleaning the paper feed roller with isopropal alcahol
Posted on Jan 13, 2009
MY BROTHER MFC 9440CN KEEPS SAYING NO PAPER RELOAD PAPER IN MP TRAY
not sure if your on copy mode or print mode ..close the MP tray door....turn off then on go to general setup select tray 1. not sure if your on copu mode or print the machine wants you to add paper to the tray that needs it. if you add paper dowes it still say"add paper" .if this is the case then the tray sensor is 1)broke2) pushed out of the way folded3) tray feed roller are not installed correctly no allowing sensor ..make sure your printer settings(properties) are set the that tray.
Oct 16, 2014 | Brother MFC-9440CN Laser Printer
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Unable to init. 50 on mfc-465
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge2_bing.gif/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
Jan 31, 2010 | Brother MFC-465CN InkJet Printer
My printer saying no paper fed there is paper in it and no paper jam doesn' seem to be catching paper
clean the rollers that help the paper feed into the machine with a clean cloth and rubbing alcohol...
Dec 21, 2009 | Brother MFC-465CN InkJet Printer
Keeps telling me to fill paper in manual feed -- I need to type an envelope. Where is the manual feed?
Hello there, ocon7954.
The manual feed tray is actually right in the front of the printer. It is that slot in between the two blueish sliders above the main paper tray in the exact middle of the door.
Since it kinda blends into the front, a lot of people miss it.
All you have to do to use this tray is to place the paper into it, then the machine will "grab" it and prepare it to be fed.
Good luck solving your problem. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC - 7420: Paper will not feed!
Does it make the same sound if you feed the single sheet through the bypass with the paper drawer removed? I hate to say it, but your printer's paper feed mechanism may need replaced. Go to http://www.brother-usa.com/AskUs/default.aspx and ask Brother to diagnose this one; I think they'll confer with me and should be able to point you to a nearby Brother-authorized repair center. Let me know what happens!
May 07, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-465CN InkJet Printer Logo
621 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
