Question about Xerox Office Equipment & Supplies
How do ya reset fuser code (H-4) Xc1044 Xerox?
Lost power-need to reset fuser
    President:
  • 2,072 Answers
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Posted on Nov 26, 2008
Reset xerox phaser 5550
To reset the maintenance counter (assuming it is the maintenance kit you need to reset)
1. From the Main menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life.
Aug 01, 2014 | Xerox Phaser Office Equipment & Supplies
I turn my xc1044 copier on and get a H3 code and machine will do nothing
You can try resetting the code. If it comes back then the machine will need service. The H3 code is a fuser code which is the part that gets hot right before the paper exits the machine.
Press the C key then the far left key then the C key then the far left key. So C,far left,C,far left
These 4 keys must be pressed within 4 seconds. If done correctly your display will go blank.
If so then key in 14 as if your were going to run 14 copies then press the print button.
This will reset the code, at least temporarily. The H codes sometimes pop up when there is no issue with the copier.
If it comes back you will need a repair person.
Good Luck and Thank You for using Fixya.
Mar 11, 2010 | Office Equipment & Supplies
Xerox copier model #XC1044 paper will not come out of the pathway, will only copy the first half of the sheet. Is this worth fixing, copier has never been serviced in 11 years! Do I need a new copier?...
Most likely the gear that drives the fuser heat roll broke.
It would be laying in the back of the machine about 2/3 of the way through.
Its not an expensive part nor hard to change. Just open the machine, look toward the back behind the hot area of the machine, I am guessing you will find broken pieces of gear. If so let me know and I will tell you where and how to replace it.
Jan 29, 2010 | Xerox Office Equipment & Supplies
How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Dec 15, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Need repair manual for Xerox XC1044 copier
These manuals are usually only available to technicians in authorized dealerships. You might try ebay.
Jul 03, 2009 | Xerox Office Equipment & Supplies
Xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
May 10, 2009 | Xerox DocuColor 3535 Copier
Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
Jun 30, 2008 | Xerox Office Equipment & Supplies
Error code H3 displayed on Xerox XC1044 Copier
this is the solution:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode' (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
To exit diagnostics: Press 'Clear' repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select '14' followed by 'Print'... exit diagnostics.
H3 stands for high temperature at the fuser.
Mar 15, 2008 | Computers & Internet
Xerox WorkCentre 255
CAUTION: The Fuser Roll remains in a cammed-up position if power to th... The Fuser Roll will not be released from its position until the power ... To prevent damage to the Fuser Roll, switch the Power On as soon as po... more..
follow the instruction in the link::
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=190,E=0000000000540251539,K=2161,Sxi=15,Solution=obj(7723)
Nov 26, 2007 | Xerox DocuColor 12 Printer
478 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
