Question about Meridian 9516 Corded phone
Editing Directory in a Merdian 9156 Phone
Palonek would like to know how to edit a name and number once stored in the directory of a Merdian 9516 Phone
There is a directory button on your Meridian-press this button and press the down arrow key until the name is displayed in the display window and press your left arrow key to change the name and number after making the correction press your save button to store.  I hope this helps.
Posted on Dec 03, 2008
Why does my printer print a file name. directory,template,creation date,last saved on,total editing time, etc?
HP Customer Service Number, 1-877-227-5694 HP Customer Service Phone Number and HP Customer Support Number to resolve hp printer, laptop issues by HP Printer Support Phone Number 1 877 227 5694 USA Printer Repair
Sep 06, 2017 | Computers & Internet
Panasonic KX TG2770 phone system I'm trying to store a voice mail access number given to me by my phone company, but I cannot find any way to get it entered into this phone. I would think this phone...
Try adding your voice mail access number into the directory of the KX TG2770. You will need to enter the number separately for the base and the handset or copy it from the base to the handset. On the base, press Conf/Edit. Then navigate (up/down arrows) to Save Directory. Once in this submenu, you'll be able to add a name and phone number.
Then to call the access number, go to the directory list and locate the name/number and call it.
Panasonic has the manual for your phone here: http://service.us.panasonic.com/OPERMANPDF/KXTG2770S.PDF . See page 33 and the following pages.
I hope this helps.
(Other phones have a voice mail waiting icon and let you program that number outside of the directory. These also check if you have voice mail waiting for the line that they are connected to. This phone doesn't seem to have that ability.)
Oct 27, 2011 | Panasonic KX-T7730 Corded Phone
How do i change my phone from numbers to letters
I am not sure about the brand & model number you are using. But in NOKIA phone you need to PRESS # for more than 5 Seconds then it will change to letter, word & vice versa.
Thanks...!!
Oct 17, 2010 | Lands Phones
How do i restore the directory
If you want to restore the directory hierarchy that contains the examples and sample programs that shipped with the calculator
  • Press [alpha][alpha] to lock the alphabetical keyboard.
  • Press [TEACH] then [ENTER).
  • The programs and examples will be restored.
If you want to create a directory (from scratch)
  1. Press [Right Shift Cyan key] and [HOME] to get back to the main directory.
  2. Press [Right Shift Cyan key] [VARS] to access (MEMORY) management
  3. Press the [D:New] tab
  4. The new variable screen opens
  5. Use the DownArrow twice to move cursor to the third line (_Directory)
  6. Press [C:Chk] to put a Check mark to the left of Directory
  7. The screen will change to show [Name and Directory]
  8. Use Up Arrow to move cursor to the first line (Name)
  9. Press [A:edit]
  10. Enter the name and then press [F:OK]
Once the directory is created you can use the Memory management to copy OR Move objects from other directories to the new one.
May 10, 2010 | HP 48gx Calculator
How to switch fixed dialling on nokia n73?
Press menu button and select Contacts > Options > SIM contacts > SIM directory to see the names and numbers stored on the SIM card. In the SIM directory you can add, edit, or copy numbers to contacts, and you can make calls. To view the list of fixed dialing numbers, select Options > SIM contacts > Fixed dialling contacts. This setting is only shown if supported by your SIM card.
Oct 17, 2009 | Nokia N73 Cellular Phone
I have 5.8 vtech phone. A set of 3. I would like
Delete a Number/Name Stored in the Directory
1. Press . The screen displays DIRECTORY.
2. Press or to scroll alphabetically through entries stored in directory.
— OR —
Press the dial pad key for the first letter of the entry you want to delete.
3. When the screen displays the entry you want to delete, press select . Then press or until
ERASE flashes.
4. Press select . The screen displays ERASE NO YES and the number. The current choice
flashes.
5. Press until YES flashes.
Sep 07, 2009 | Lands Phones
Active directory is rebuilding
if u edit settings in active directory and editing the rools
bake up your setting
and remove active directory
them stup it agien
Nov 06, 2008 | Microsoft Windows Server Standard 2003 for...
Caller id
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
Oct 13, 2008 | Panasonic KX-TG5672 Twin Cordless Phone
NEC DTU-8D wiping the directory list
If it is in the system speed dial directory you have to go one by one and type "Feature, Redial, bin # where it is stored (system 00~79, station 80~99), Feature". This should wipe each Speed Dial listing.
If it is in the voice mail unit you may want to go phone by phone and log into the box. You will need to redo the following:
Personal Greeting
Recorded Name
Spelled Name
Directory Listing
Security Code
All these options are listed in each mailbox through a series of soft keys. Let me know if you need more info.
Aug 13, 2008 | NEC DTH-8D-1 Corded Phone
Contacts
If you have phone numbers stored on the SIM card, copy them to Contacts. Entries that are saved ONLY on the SIM card are not shown in the contacts directory. So for incoming calls and msgs, the phone cannot match the number to the name.
To copy individual names and numbers from a SIM card to your phone contacts:
Menu/Contacts/Options/SIM contacts/Sim directory. Select the names you want to copy and: Options/Copy to contacts.
Feb 08, 2008 | Nokia N70 Cellular Phone
Meridian 9516 Corded phone Logo
139 people viewed this question
Top Meridian Lands Phones Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Meridian Lands Phone Expert? Answer questions, earn points and help others
