Question about ASUS P5P800S Motherboard
Error Boot "Chasis Intruded fatal Error System Halted"
HI,
When i boot PC show messsage error "CMOS Checksum Bad, Chasis Intruded, Fatal Error, System Halted" and i can't logon to menu BIOS setup if i press DEL or F2
  • achdi zamil Dec 01, 2008
    For Information BIOS menu no password
  • Anonymous Mar 27, 2009
    chassis intruded
    fatal error halted
    Sergeant:
  • 177 Answers
Well it seems like that the cmos battery is down. You need to do the following
Change the CMOS battery,
Enter into bios and change the date and time properly,
Save and exit bios.
Now you should be able start your computer in windows.
Posted on Nov 26, 2008
  • chiraath Feb 23, 2011
    error"chasis intruded , fatal error , system halted"
    change the chassis signal jumper to a new one
    CLK
    Sergeant:
  • 207 Answers
Achdi,
Something has tripped the chasis intrusion on the motherboard.
This is a security device that disables the system should someone unauthorized open the case.
Unplug the power supply, open the case. Down near lower edge of the board there is a connector with several wires attached marked Panel a bit farther up from that there is one marked CHA_FAN between that is one marked CHASIS this is the connector we need to deal with. If there are wires attached to it trace them back to the module attached to the case. there should be a reset switch on this device be sure to reset it just before closing the case again. If you can not find a reset switch on it remove the wires from the connector and tuck them away (Note doing so will mean the intrusion detector will not function any longer) If there were no wires look carefully to see that nothing has shorted (connected the pins) accidentally. If so it might be advisable to blow out the case with a can of compressed air to prevent it from happening again.
OK now we need to clear the fault from the bios. There is a battery (Silver disc: watch style) on the board. Pull the battery. Now there is a 3 pin connector near the battery marked "ClearRTC" that has a jumper on pins 1&2 move it to 2&3 now wait for 15 to 20 seconds
restore the jumper to pins 1&2, replace the battery, close the case.If the intrusion detector is still functional reset it. Plug the cord back in and boot up the PC you should now be able to get into it.
You will have to go into BIOS to adjust settings again including set time and date.
If this method does not help then the error is likely internal on the motherboard, and will need to be repaired or replaced by an authorized service tech.
Hope this helps
Dave
    Scholar:
  • 134 Answers
Try to reset the BIOS to factory settings
1. Turn off the power and unplug the power cord.
2. Remove the onboard battery.
3. Move the jumper capfrom pins 1-2 (default) to pin 2-3 keep it to 5 to 10 sec. then move the cap back to 1-2.
3. Re-install the battery.
4. Plug the power cord and turn-on the computer.
5. Enter the BIOS set-up by holding the DEL key and re-enter the data.
i hope it helps!!!
  • Fernando Cruz
    Fernando Cruz Dec 01, 2008
    Chasis Intrusion connector (4-1 pin Chassis)
    This connector is for a chassis mounted intrusion detection or
    sensor or switch. Connect one end of the chassis intrusion sensor or
    switch cable to this connector. The chassis intrusion sensor or switch
    sends a high-level signal to this connector whenn a chassis component
    is removed or replaced. The signal is then generated as a chassis
    intrusion event.
    By default, the pin labeled 'chassis signal' and 'ground' are
    shorted with a jumper cap. Remove the jumper caps only when you intend
    to use the chassis intrusion detection hardware.
    I hope it helps!!!
  • wallker Aug 21, 2010
    Guys I have this problem but at first i thouth it was in HDD i buy new one but i find out it isnt so with this eror thath gives me when i restartart pc it starts normally but when i start it makes me all time erors on games,browsers it restarts alot of time suddenly and etc. I wanna ask is this the same problem and do i try fix it how you said it or it is another way?
Cmos checksum bad Chassis Intruded Fatal Error System Halted!
To remove CMOS Checksum error, you have to remove the coin cell battery from the motherboard and install a fresh one. A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
For Chasis Intrusion msg, go to the BIOS (when prompted, press the Function Key at the system startup) and locate the option of chasis intrusion option and disable it, save settings. Commonly, to enter the BIOS you have to press F2, F10 or DEL Key, depending up the make/ model of the PC you have.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 08, 2011 | Computers & Internet
Cmos checksum bad.chassis intruded fatal error ..system halted.
Make sure that the Processor Heatsink is tight. Try replacing the CMOS battery.
Hope this helps!
Apr 15, 2011 | ASUS P5P800S Motherboard
A massage display when started pc - chasis intruded, fatal error
enter the BIOS and turn of the chasis intrusion warning.
Jun 06, 2010 | ASUS P5GC-MX/1333 Motherboard
How to troubleshoot the error message of my pc? CMOS Checksum Bad Chassis Intruded! Fatal Error...System Halted.
looks like you have a bad ground connection in your motherboard, check all the connections , then restart the machine with the minimum devices conected...
thanks
Jun 01, 2010 | ASUS P5GZ-MX Motherboard
Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Dec 17, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Sep 29, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
ASUS P5VD2-VM SE MOTHERBOARD
If you purchased this motherboard recently then i would double check your power supply - get a better power supply and try that - think you may need one with two 12 volt rails.
If that does not work then I would get it RMA'd as in return it and get a replacement.
Apr 10, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Chassis Intruded
clear your bios, close very good your case, open bios disable chasisis open detected fro yes to no, (or in some model from enable to disable ) change saves exit booting and good work.
Apr 07, 2009 | ASUS A8R32-MVP Deluxe (A8R32MVPDLX)...
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Nov 26, 2008 | Computers & Internet
ASUS P5P800S Motherboard Logo
9,886 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
