Question about Brother IntelliFAX 560 Plain Paper Fax
How do you set the number of rings on a brother 560 fax machine
I need to set number rings before fax picks up
  • 827 Answers
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Posted on Dec 21, 2008
PLEASE HELP ME SET UP MY BROTHER FAX-560 TO RECEIVE FAX AFTER 4 RINGS. THANKS, JOANNE
You should check the manual for the fax machine. It gives detailed description of how to do it.
The information you need is on Chapter 5 - Set Up Receive.
In short, you will have to:
(1) set the Answer Mode to "Fax/Tel";
(2) set the Ring Delay to 4 (that's the default value, so do nothing unlese you have changed the value before. Values are 0 to 4)
(3) Set F/T Ring Time
If you don't have the manual, you can get it from ManualsOnline at:
http://office.manualsonline.com/manuals/mfg/brother/brother_intellifax_560_ppf560.html
Right click The blue "Get This Manual" button anda save the file to you computer.
For a limited time, you can also find a copy here:
http://files.getdropbox.com/u/1322442/UM_Personal%20FAX_560_EN_73.pdf
Apr 28, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
Help when i try to fax using my brothers 560, the number dials, the machine sounds like it's faxing, but the disply says telphone. how can i correctthis
Do you pick up the hand set when you are dialing, If you do the display will read telephone. When you want to send a fax put the paper in the document feeder. Dial the # press the start key or put the documents in the document feeder press the hook button to here the dial tone, dial the number what for the tones pres the start key. hope this helps
C.W.H.
Jan 29, 2009 | Brother IntelliFAX 560 Plain Paper Fax
BROTHER FAX-560 THAT IS NOT WORKING TO FAX OR RECEIVE
Look in the manual for setting up receiving faxes. There is a default number of rings setting that will make your machine capture the phone line after a specified number of rings.
Jan 07, 2009 | Brother IntelliFAX 560 Plain Paper Fax
How can i change the ringer on my fax machine?
Setting Ring Delay:
Chris (ziraffa)
Dec 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother intellfax 2800
Scroll through the menus for NUMBER OF RINGS
Oct 20, 2008 | Brother IntelliFAX 2800 Laser Fax
Setting fax number for my machine
Thanks for the quick return offer. We did get it fixed by taking the machinea and cartridge to Staples and there was a gentleman there that knew the problems fix. Thanks again.
Mar 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Panafax UF560 - how to set so confirmation page is automatic ?
Function 7 4 set.
07 (Header Print)
Setting number 1 (Inside copy area) 2 (outside) 3 (none)
Set.
You can also set the header format with Parameter 08(Header Format) 1 is for your Logo and fax number. 2 is for From: to:
Feb 01, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Brother IntelliFAX 560 Plain Paper Fax Logo
270 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
