Question about GN Netcom GN 9120 Professional Headset
Echo when using the headset
When using the headset i hear my own voice, i have tried adjusting the volume but to no avil still doesnt work right
  • Anonymous Dec 27, 2008
    I've tried the volume settings and still echoes, please help
  • Anonymous Mar 12, 2014
    I used the call function and the caller can hear their own voice echo. I tried the headset on another device and the problem still occurs. I am currently using samsung galaxy note 3. Please help. Thanks
If you are having echo problems while not on a call (you are wearing the headset, it is active, but you are not currently on the phone with anyone), there are 3 ways to counteract this: -When you are done with a call, you can click your Multifunction button on your headset (middle one inbetween the volume controls). -Move the microphone away from your mouth when you are not on a call. -A more permanent solution: decrease the sensitivity of your microphone. To do this, click and hold the increase and decrease volume buttons on your headset ( + & - ) for 3 seconds. Let the buttons up after 3 seconds and push the lower volume button 2 or 3 times. Wait 6 more seconds and it will beep at you. After you have done this, make a call to someone in the office to be sure the sensitivity has not been lowered so much that others can?t hear you.
Posted on Jan 17, 2007
Bad echo in ear piece while talking
You can try adjusting the volume and see if any results. Try to verify if it is a hardware defect by using a Bluetooth piece and if you get better results.
Nov 08, 2013 | Plantronics CS530 Wireless Headset System...
Friends hear echo when headset is on in x-box live party chat
I had the same exact problem with a brand new x32 headset. right out of the box it was echoing for my friends. Also, if I muted my mic it would kill the chat volume (ie barely even audible). I switched the voice to play through speakers and it worked flawlessly after that.
Not sure if it is a hardware issue with my controller (my other headset worked just fine) or if it is a defective cable I received, or a design flaw with the x32. If you are looking for a work around, try setting it to play through speaker.
May 15, 2012 | Voyetra Turtle Beach Tbs-2265 Ear Force...
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Jul 18, 2011 | Plantronics CS70 Wireless Headset
I can't hear anything from my logitech headset
Hi Itsyen, go to start menu, control panel, sound. Then here go into the Tabs and select the Headset as Mic and Speakers. Apply, Done !
Thanks and have a nice day Julien
Aug 04, 2009 | Logitech 250 Headset
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
I am getting feedback with Plantronics CS70 Wireless Headset
Jun 05, 2009 | Plantronics CS70 Wireless Headset
Outside caller hears themselves in an echo
Jan 23, 2009 | Plantronics CS55 Wireless Headset
New Phone Causing Echo
It sounds like your microphone volume is too loud. Get someone on a call with you so they can tell you how it sounds as you adjust it. Turn down the mic volume by pressing the + & - buttons on the earpiece together once which puts the earpiece into mic adjust mode. Then decrease the mic volume by pressing the minus button a few times until it sounds right. The earpiece will automatically revert to normal mode within a few seconds.
If this doesn't work it may be that you need to adjust the compatibility setting for the new phone. This is the small black dial on the base station. The most common setting is 'A' but you may need to experiment with other settings for that phone.
Nov 04, 2008 | GN Netcom GN 9120 Professional Headset
Echo Problems
hit the sound icon on your desktop rightclick it, go to Recoringtools turn down the microphone! As in the picture.
Im sorry its dutch :-)
Jan 21, 2018 | Motorola Mobility H500 Wireless Headset
Echo problems
Check that the MIC is muted in the volume control but not in the recording settings. This could just be feedback.
Mar 20, 2007 | Plantronics .Audio 340 Headset
GN Netcom GN 9120 Professional Headset Logo
2,775 people viewed this question
Top GN Netcom Radio Communications Experts
Tom Chichester
MrFixitSTTL
Clint Millett
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
