Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Winterizing a LXIH Hobart dish washer
We are shutting our Lodge down for 3 months and need to winterize the dish washer. Will probably get down to 0 degrees. It is hard piped in and would cutting the pipe and draining be enough.
thanks, Joe
  • 4 Answers
Joe - The main issue is that the builtin booster heater is full of water - it has to be drained - there may be a small drain plug (square-shaped head), if not, you may have to pull loose the heater element to drain the tank. I would pour antifreeze solution in there and also in the wash tank. Unhook the water inlet - you say the machine is hard-plumbed in but mfgr recommends using brauided water hose to connect to water supply. hopefully this helps - I service commercial machines and came across your question and maybe you can ansqwer one of mine - how do I cancel the "delime" indicator? I can't find operators manual. jimmy.
Posted on Nov 26, 2008
  • 41 Answers
Hi i am a hobart certified tech the only way to cancel your delime is to cancel this function in the service mode. also you must crack open the fill valve on parker valve and let the water leak out of the bonnet or the valve will split when it freezes
Posted on Dec 07, 2008
This dish washer works fine except one thing. How do I raise the temperature up?
Are you having problems with the heat? You may have a bad heating element.
Feb 26, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Wash Temp will not get above 140
It depends on the design & the programming. By chance if the thermostat is faulty this can happen. However refer user manual and consult the service provider or the manufacturer!
May 21, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LXIH dishwasher
You can add a small amount commercial dish soap to the wash chamber before pressing the wash button.
Apr 02, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
When we push the Off button the machine won't drain and shut down? this is a Hobart LXIH machine. thanks,
Try disconnecting power from the unit either at the plug or the breaker if hard wired. Reconnect the power and turn it on. If the water drains, refills and operates as usual, your problem is likely a bad off button on the membrane switch. Let us know
Sep 17, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Wrench and code p3 display
this is a probe booster error your probe failed replace it
Dec 09, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Oct 14, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E-5 error code and no draining or rinse cycle machine less than 3 months old
E5 is a drain error - machine is not draining - check drain hoses - pull out machine if needed - check air gap. hope this helps. jimmy.
Sep 26, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LXIH displays P2
The rinse thermistor is bad,look on the back of the machine to the right and you will see 2 black wires with a plug that screws into the vac breaker this is the probe.I bet when the dishwasher goes into the rinse cycle the temp jumps all over,let me know.
Jul 27, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lxih
E4 indicates water level has not reached top water sensor. Check for proper flow-water pressure to machine (15-25psi) and clean sensor in wash tank
Jul 16, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
272 people viewed this question
Top Hobart Dishwashers Experts
Marvin
Marvin
Garth Jackson
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
