Question about Lexmark X1270 All-In-One InkJet Printer
Receiving Fax using a phone line with voicemail on a Lexmark 5470
I have a phone line with voicemail (not a separate answering machine). I have the fax set up on the same line.
I have set the number of rings for the fax to be at 3 and the voice mail at 5. However, if someone calls for voice, the fax machine picks up at three rings with a squelch. I have also tried it in reverse with no luck.
How can I receive calls and faxes without disconnecting one or the other?
    Problem Solver:
  • 5 Answers
Well, your voicemail can configure to key tone?? or have some one configuring options????
Posted on Nov 26, 2008
Lexmark platinum pro905 fax
If you're having problems sending faxes, make sure that the printer is connected to an active phone line. The best setup would be to connect the printer straight to a wall jack and the other end of the phone cable should be connected to the line port at the back of the printer.
If you're having receiving faxes, check the fax settings > Ringing and Answering. Check if the Auto Answer is enabled and check how many rings the fax will pick up any faxes sent to your number. If you have an answering machine connected to the same line, set the printer to pick up 3 rings higher than your fax machine. If you have a voicemail service, you'll need to get a distinctive ring feature from your phone provider.
Oct 29, 2012 | Lexmark Platinum Pro905 multifunction...
How do you get the fax machine to work?
First, make sure that the printer is connected to an active phone line. The best setup would be to connect the printer straight to a wall jack and the other end of the phone cable should be connected to the line port at the back of the printer.
For receiving faxes, check the fax settings > Ringing and Answering. Check if the Auto Answer is enabled and check how many rings the fax will pick up any faxes sent to your number. If you have an answering machine connected to the same line, set the printer to pick up 3 rings higher than your answering machine. If you have a voicemail service, you'll need to get a distinctive ring feature from your phone provider.
To get more information on how to setup the fax, check this manual: http://bit.ly/PCKt7z
Sep 05, 2012 | Lexmark "x264dn multifunction laser...
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
Lexmark pinnacle pro901 will not receive faxes i can send but can not receive what do I do
Are you sharing your home phone line with your fax? Do you have an answering machine or a voicemail feature in the same line?
If you have a voicemail feature in the same line as the fax, you may want to subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Nov 02, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I cannot receive incoming fax, what setting do I have to use
Please go through the following checklist:
  • Make sure to plug the telephone fax line from the phone jack in the wall to the Line port on the back of your printer. For more info, please refer to the Lexmark X4200 User's Guide.
  • Make sure the fax machine is connected to right phone jack in the wall and is assigned with the correct fax number.
  • If you have an answering machine connected to the same fax line, be sure to configure it so that it answers first before the fax machine (e.g. if your answering machine picks up on the 3rd ring, set your fax to pick up on the 6th ring or more)
  • If the line has a voicemail feature, disable it or request for a distinctive ring from your phone company.
Sep 13, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have a lexmark x5650 printer and I can send a fax but I cannot recieve a fax. Can you please help me?
Ensure that the telephone/fax line is plugged into the Line port on the back of Lexmark printer and not in the Phone port.
Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
Can send faxes but not receiving them and yes there is paper in fax
Make sure the correct fax number is assigned on the printer. If you have an answering machine connected to the same line as your fax, configure it so that the answering machine picks up first then the fax. For more information, please refer to this article: Change Number of Rings on Inkjet AIO to Alleviate Issues with Answering Machines.
If you have a voicemail feature associated with the fax line, please disable the voicemail. Voicemail feature and the fax will not work together in the same line.
Jul 05, 2011 | Lexmark X4270 All-In-One InkJet Printer
We can't receive a fax!!! how are we supose to connect with a phne line and the computer???
You don't need to have a computer plugged in to the Lexmark printer to receive faxes. Here's an article on How to Configure the Lexmark X7170 to Receive Faxes. Just click on this link: http://bit.ly/d643uT. If you are sharing your home phone line with the fax and you have an answering machine on the same line, make sure to configure the answering machine to pick up first then the fax machine. Voicemail feature can also block incoming faxes. Once voicemail picks up the fax, signal won't be passed on to the printer. But if you want, you can also contact Lexmark technical support to further investigate the problem.
Aug 12, 2010 | Lexmark X7170 All-In-One InkJet Printer
Receiving faxes
Call the fax machine using a regular phone to see if it answers.
Jun 01, 2010 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark X1270 All-In-One InkJet Printer Logo
138 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
