Question about Kitchen Ranges
Oven turns on then flame flutters on and off
Take s a long time to get up to temperature. Broiler works fine and top burners work fine.
  • theheils Jan 16, 2009
    Kenmore model 36275501990 oven doesn't come up to temp. If I tap on the back where gas line goes in, then it will flutter and sometimes actually light completely and work.
SOURCE: viking oven won't heat
Igniters need to be replaced
Posted on Aug 26, 2008
SOURCE: GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Posted on Nov 15, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Oven burner seems to have low flame
Check voltage to gas valve in the back of the boiler compartment. It is way in the back on the left hand side, turn on the top burners. If you do not get any volts or only 1 to 5 volts you will need to replace, It is supposed to have 24 volts to operate correctly
Posted on Feb 09, 2009
Maytag317
  • 1136 Answers
SOURCE: broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
Posted on Jul 17, 2009
heatman101
  • 43501 Answers
SOURCE: top oven not heating up on BAKE, broiler gas and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Jan 09, 2011
I have changed the brners over and thay work fine. But the only thing I could find to change on the oven was in the back.I flipped the orifice but oven smoke3s heavily And flames are too high.
You must remove the oven racks and the base pan inside the oven to access the bake burner gas valve. Using a 1/2 open end wrench you will tighten the orifice on top of the gas valve until the flame is the correct length.
If your model has a top broiler,the broiler gas valve will have to be adjusted also.
Nov 08, 2009 | Kitchen Ranges
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
Maytag oven will not get hot
the ignitor is bad, the ignitor opens the valve when there is enough amperage. the ignitor isn't pulling enough to fully open it
Sep 08, 2009 | Maytag MGR5870 Gas Kitchen Range
Broiler works, oven settings - no flame, no heat.
Thanks
Vic
Jul 17, 2009 | GE JGBP33 Gas Kitchen Range
Feb 09, 2009 | Jenn-Air JGS8850AD Gas Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
