Question about Brother IntelliFAX 1270E Plain Paper Fax
Fax machine will not recv faxes will copy, did have it on tad
But changed it to fax. still not recv, but will copy
  • Anonymous Dec 09, 2008
    fax says check paper----paper seems fine
  • 2,120 Answers
Check the phone line with a regular phone.
Make sure phone cord is plugged into the LINE port of the fax machine.
Posted on Nov 26, 2008
Fax machine is not picking up fax, goes to answering machine
Check the display, does it say fax or tad, if it says tad press the MODE button until fax is displayed.
Aug 05, 2011 | Brother IntelliFAX 560 Plain Paper Fax
I have a Brother Fax 2820 at home. It is connected to a TAD. I want an external fax machine to send and bypass the voicemail greeting and print the fax. I thought I set the machine to TAD. Any other...
try this paul. hook your phone line from your wall jack to your "line" jack on your fax. then run another phone line from your "external" jack on your fax to your "line" jack on your TAD. now, make sure your fax machine is still set to TAD. here is whats important...set your TAD to 4 rings or less. 2 is the recommened setting. also very important...when you record your outgoing message on your TAD, make sure you leave about 5 seconds of silence before you start recording your message. the reason for this is the fax machine needs to "hear" the CNG tones that originate from the sending fax so that it knows its a fax and then can take over the call. if it doesn't hear those tones because of noise (voices, etc), it will let call go to TAD. you can try to set your TAD to 4 rings, but that doesn't leave much time for fax to "hear" these tones. if you set to 4 and don't get all your faxes, try lowering the setting to 2 or 3 rings.
good luck and hth,
Mar 02, 2011 | Brother IntelliFax-2820 Laser Fax
I have changed from a desinated fax line to sharing a phone and fax line. the fax machine rings along with the phone however the fax does not answer. i was told to purchase a ring decipher but cannot...
Your fax can share the line with your phone, but it needs to be set to answer or not, depending on your equipment and choices.You can download the manual from Brother here. The receive modes are explained on page 5-1.
If you're often out when faxes or phone messages might come in, you probably need to plug an answering machine into the back of the fax (the EXT. jack) and put the fax in FAX / TAD mode. (TAD stands for Telephone Answering Device. Be sure the TAD is set to answer before the fax does. The fax will pass the phone call through to the TAD, and if it hears the beeping of another fax sending, it will cut off the TAD and take the call.
See the manual for more info and other options.
Feb 15, 2011 | Brother IntelliFAX 2600 Fax
TAD error
Change the RECEIVE MODE to FAX ONLY. TAD stands for telephone answering device which is used if one of this device is attached the EXT port.
Dec 08, 2009 | Brother IntelliFAX 560 Plain Paper Fax
you need to change your mode key to fax only
Oct 26, 2009 | Brother Office Equipment & Supplies
My fax machine says enternal tad.
TAD stands for telephone answering device. you have to change mode to either fax or phone/fax.
Auto answer is also another option on some faxes
Jun 22, 2009 | Brother FAX-575 Plain Paper Thermal
Brother fax model 575 in Manual recieve Mode,won't change
Telephone Answering Device (TAD). This is the mode you use when you have answering machine active on your phone line.
Mar 27, 2009 | Brother FAX-575 Plain Paper Thermal
Brother Intellifax 1270
There is a help menu on this machine. To print this out, just press the help button. To change the fax/tel ring, 1st have in mind how you want your fax machine to work. Do you have an a TAD connected? Do you want the fax machine to take priority over tel calls? The fax machine seizes the line after the set number of rings, that means any other device connected to other phone outlets, will not answer after the fax has answered. Have this in mind when you set the ring time. The TAD will have it's own ring time too.
Feb 29, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
What does "TAD" mean when it appears on the screen?
TAD is Telephone Answering Device. TAD mode is the only mode that can be used with an external telephone answering device (unless you are using a distinctive ring number for receiving faxes). Your telephone answering device must be connected to the jack on the fax machine (labeled "EXT" for USA). When someone dials your telephone/fax number (to send a fax or to speak to you), all the telephones (including the FAX) will ring according to the number of rings you set on the TAD. The Ring Delay setting is not recognized in the TAD mode. If you do not answer the call, the TAD will answer. As your outgoing message is playing, the Fax is in the background, silently listening for fax tones. If the FAX hears fax tones, it will automatically go into the receive mode. If the FAX does not hear fax tones, it remains silent, allowing the caller to leave a message. The above information is correct for a Brother fax machine. Is your fax automatically picking up the call or do you have to push a panel button to start the receive fax process? Perhaps the fax is already "in" your fax machine's memory and only needs a manual printout. Check the fax call log.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 1270E Plain Paper Fax Logo
41 people viewed this question
James Cagle
James Cagle
Jim Keysor
