Question about Philips 50PF7320A 50 in. Plasma HDTV
Philips 50" plasma ysus board troubles
Hi I have A philips model # 50pf7220a/37 50" plasma And When it is pluged in The green light flsahes red in a 7 blink cycle.
I have narrowed the problem down to the ysus board.
I was churious If anyone knew what component an the board may have gon bad?
Or if anyone had a repair manual for these boards?
The pcb# is lh14-03217a
  • bigslinkys Dec 13, 2008
    ok thanks
    I found a blown fuse.
    I replaced the y sus and y buffers the tv works great now.
    the previous owner said he had it on the wall for a year before it went bad..
    typical over heat issue with these tv's as I have found out.
  • 116 Answers
Check for shorts, blown fuses on ysus, if blown replace entire board, easier than locating many of the parts installed on the board.
Posted on Dec 11, 2008
  • Justin Washburn Dec 13, 2008
    wow you got lucky on the ysus if it just popped a fuse, when mine went i ment IT WENT....lol glad you have it fixed. woohoo
    i mis understood so you did have to replace the ysus? still very cool.
Philips 50'' Plasma TV model 50pfp5332D/37 GREEN BLINKING ON LOGIC BOARD
Main digital processor IC on the board has damaged. It is not a replaceable part, as normal soldering techniques cannot be applied to de-solder it out from the board, or to solder a new one in place. Card base replacement should be done.
Aug 14, 2012 | Philips 50PFP5332D 50 in. Plasma...
Philips 50PF9630A/37 plasma TV will not power on and has a red blinking light - 6 slow flashes then 3 quick flashes . I've been having the issue on and off for about 2 weeks. seems like when I ...
Hi.
The TV is forced in standby because an internal fault has been detected. 6 blinks slow and three fast blinks points at defective Ysus board or defective buffer. The power supply must also be tested. Till now the TV was starting because when you disconnect power you discharge internal components. Some of the components have the role of storing charge (the capacitors). If a capacitor is defective the TV may still work as other components will compensate the function of the faulty part. After a while more components will fail and the TV will not start anymore. To fix the problem the TV must be tested at component level. Testing will start from PSU voltages to YSus and buffer boards.
Regards.
Ginko
Aug 04, 2011 | Philips 50PF7220A Television
Plasma Philips 50
Ur power board have burn capcitors,like puff up or burst open,must changes these capacitors.Know how to solders?Tries Shopjimmy.com,Ebay.com for buying reburbish power board.
Jan 11, 2010 | Philips 50PF7220A Television
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips 42PF9630A/32 Plasma TV RED led blinking 7 times
Are there any blown caps on the PSB-power supply board. Most sets have sammy boards and they used very shotty caps. If there are no visual clues being a poped cap at the top (X) they simply often do vaporize and dry out. The YSUS-Main and the 2 Y buffer boards control the picture OSD-on screen display. Your not getting any of that. So power supply is where you start first. The YBU-upper and the YBL-lower control the upper and lower OSD the Ysus main control both of them. Usually if you have one in the door you have to replace all 3. But not always. If you were to replace any of the boards I would replace the YSUS-Main, or get the board reworked at a pc repair shop that does board level test and repai. Its more cost effective.
Best Regards and Semper Fi
Oct 12, 2009 | Philips 42PF7220A 42 in. Plasma Television
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
has only one main board
has many sub bords supporting tat main board
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
Phillips 32 in plasma
Hi there!
May be Ysus or Zsus board. Can't help you with support and pricing unfortunately. Good Luck,JUS004
Mar 08, 2008 | Philips 32PT6441/37 32" TV
Philips 50PF7320A 50 in. Plasma HDTV Logo
977 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
