Question about JVC DX-T9 System
Jvc DX-T9 system unstable
I have a JVC dx-t9 home theatre system which continously switches from DVD, tape, radio and Aux mode. that is, it plays dvds for sometime switches to tape e.t.c. how do i solve this?
  • 130 Answers
SOURCE: System unresponsive when modes are switched
Arnt they seperate things? ive seen some systems that dont function if thery are not in that mode. If its in DVD mode nothing on the DVD works, if its in the radio mode maybe the power changes over to the tunner only? you cant play both at once maybe their idea. Will things work when its in the cd mode? Is the unit staying cool?
Posted on Apr 13, 2006
SOURCE: tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Posted on Feb 27, 2007
  • 624 Answers
SOURCE: JVC TH-M505 No Sound
It is possible that a fuse has blown in the sub-woofer box. This unit has the entire amplifier built right into the sub-woofer. It also has a number of fuses in it. I have found that over the years fixing these units that if a fuse is blown you will also have more serious problems in the amp circuit. That is usually why the fuse will blow. They sometimes even have a problem in the main head unit with a digital transistor that is a surface mounted transistor that will cause this problem also. This transistor is part of the turn on circuit that signals the sub-woofer to turn on when the head unit is turned on. None of these problems are an easy fix I am sorry to say.
If you have at least a little experience with electronics and the right tools, like a multimeter and soldering equipment, I may be able to help you figure out the problem. But be aware that these are not easy to fix, and you may spend lots of time trying to figure it out just to find out that you will still need to take it in to a service center and in many cases when somebody tries to fix these type of units and have no experience with them they often cause more problems than they have started with.
For starters you can at least check the fuses, but please be sure to unplug the entire unit from the wall outlet before doing anything, there is a big risk of electrical shock.
The bottom of the sub-woofer has 6 screws in it (If I remember right) and those 6 screws must come out, they are rather big and you must use a number 2 phillips head screwdriver. Then after that you must take out all the screws from around the edges of the black metal panel where the speakers plug in to. When those are all out you can pull the amplifier unit right out of the sub-woofer box. Be careful when you pull it out, you will need to unplug a set of wires to get it all the way out, maybe two sets of wires, I am going off of just my memory right now, but if you need more help I will look up the service manual to help you more.
You will find at least one fuse right near the board where the A/C plug goes to and then you will find a few more fuses on the board that is on the right side while looking at the amp block from the same position you pull it out from and this board is plugged into the bottom board and is vertical but the short side is up and down, the long side is going towards the back of the amp and it is running along the metal chassis on that right side.
I hope this helps you, if you need more help just post your questions here.
Posted on Nov 26, 2008
SOURCE: how do i unlock a jvc home stereo
On the unit, press the stop button and the cd eject button at the same time. The screen will say locked still. Release them and press them together again at the same time. The screen will now read unlocked. You can then eject the cd.
Posted on Dec 12, 2008
SOURCE: home theater system jvc th-d60
This is from the TH-D50 User Manual:
The connected TV is not HDCP-compatible. (“HDCP ERR” appears on the display.)
Disconnect the HDMI cable and connect it again, or use a shorter cable.
Posted on Dec 31, 2008
SOURCE: NO SOUND From JVC TH-S5 Home cinema system
I know this is an old topic however someone somewhere might benefit from this feedback. I purchased the JVC TH-S5 service manuals from and after metering all the supplies as 'OK', I then focused in on the 'common' lines associated with the two onboard power amps IC's (STK413-400) and found that they were missing a bias supply. This is derived from the onboard 40v Supply 'dropped' down by a 47 ohm resistor R2702 (rated 1/4 watt but advised to make this at least 1/2 watt). The resistor was found to be open circuit i.e. a very high ohmic value. Looking at the circuit diagram again, I would feel that this is going to be a common issue with this unit.
Posted on Sep 12, 2009
0 characters
1 Points
My cd's do play but my dvd's don't want to. How
Don't quote me I believe you can download software that rectifys this.
Have you a drop down setup menu, it could be like a lot of digi's these days you still have to click a menu to turn an item on?
May 12, 2011 | JVC Home Theater Systems
I purchased the panasonic scpt670k home theater system and hooked it up to a jvc I"art tv but when i hooked the audio out port of the tv to the auxilary in port of the home theatre systme I don't get the...
What exportable audio is originating with the TV in your scenario? I couldn't find any documentation supporting an audio output of any flavor.
Isn't the root source of the program actually a cable box, satellite, dvd or blu-ray? Wouldn't THAT be where you want the audio feed to the Panasonic to come from?
Feb 01, 2010 | Home Theater Systems
My dx-t9 dont have power
If you know how to measure, then check Transformer output (Low voltage). If not good, replace the transformer
Jan 01, 2010 | JVC DX-T9 System
I am getting the locked display
Hi Blackhawk,
This sounds like you've accidentally set the "tray lock" feature.
You can set this to stop unwanted tray ejections:
I hope this solves your problem..
Warm Regards
Nov 28, 2009 | JVC TH-M303 System
We own a Sunsung Home Theatre HTWP38. The remote
Remove the batteries and hold down the POWER button on it for 30 seconds. Then replace the batteries with fresh ones.
Hope this helps!
Jun 07, 2009 | Samsung HT-WP38 Home Theater System System
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
Power will shut down after few minutes when volume reaches 12
If you check at the back of your hi-fi, you'll see a projection at the top where the cooler fan is located. The most likely reason is that your fan is not working (as required). In this system, the fan is turned on automatically at high volumes >=10, because then, the amplifier starts to get a temperature rise and without proper cooling the system might fault.
Try check and see if at these high volumes the fan is running, if not, then that's what needs to be fixed. Alternatively you can try running an external fan to see if it will produce the desired cooling effect.
Nov 25, 2008 | JVC DX-T9 System
I am missing some parts
Jvc home theatre system cable that connects the the bub and the dvd
Jul 04, 2008 | JVC TH-M606 System
My dvd/cd try does not open when i press the eject button say "locked"
That means your trays are on Child Lock (this is a safety feature to prevent any accidental opening or closing of disc trays by small children when listening to your favorite tracks.)
To solve this, simply switch off your radio to Standby and hold the power button...whilst holding the power button, press open on the tray that is locked....the system will display UNLOCKED on the display of your hi-fi.
That should be it. To lock the tray....repeat the same process on the particular tray u want locked.
May 21, 2007 | JVC DX-T9 System
Sounds like there may be a glitch in the microprocesor. Make sure when you unplug it that you leave it along for a few days and is there any type of clock or standby batterys in it take them out as well. If that dosent correct the problem your gonna need a service manual to trace the switch pulse to see if the units Switch matrix lines are low or lost because of a faulty micro or a bad componet like a small caps they install on the matrix to keep noise off them. Hard one to call with out seeing unit and analizing unit Good Luck
Apr 12, 2006 | JVC TH-A30 System
JVC DX-T9 System Logo
Top JVC Home Theater Systems Experts
Are you a JVC Home Theater System Expert? Answer questions, earn points and help others
