Question about Panasonic EY6409NQKW 12 - Volt Drill/ Driver Kit
Panasonic EY0110 Charger
Is there a way to test my panasonic EY0110 Charger to see if it is charging properly?
I know my batteries are bad; however I suspect my charger is faulty which caused the problem
    New Friend:
  • 55 Answers
Use a volt meter attatch to the contacts and see if you are getting 12 volts .If so then your charger should be okay
Posted on Dec 05, 2008
Battery not charging
Is it a replacement battery ,you purchased, with the EXACT same specs? Some aftermarket inexpensive batteries do not work well with your laptop. How do you know it's not charging, by the Icon in the Tray Notification Area? Again sometimes aftermarket batteries don't have the ability to communicate with the software. The pin-outs are not the same.
Dec 09, 2012 | Computers & Internet
Red and green flashing lights on 18v lxt charger
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Feb 21, 2012 | Makita Tools & Hardware - Others
Charger is not workking
Sometimes, the power supply to the charger might be too high or too low hereby resulting in damaging the charger. I will advice you test the charger on another phone before you conclude that the charger is bad. Once You have confirmed that. The only solution is to replace the charger. Once you have confirmed that the problem the problem is from the charger. Then You test the battery and the phone to know where the problem is from.
To test the battery,
  1. Power off the phone,
  2. Remove the battery,
  3. Insert it in another phone,
  4. Try to charge it with another charger,
If it charges, then it means the battery is working, but if it does not, then it means the battery is bad and need to be replaced.
Further test the phone,
  1. Insert a well tested battery into the phone,
  2. Plug a well tested charger into the phone to see if it will charge,
If it does not charge, then it means the connection port is bad and if it does charge, then it means the problem is not from the phone.
Before the end of the of the tests, You will have detected the problem and the solution to any of it is to replace it.
Hope this helped. Thank You for using FixYa!!!
Jan 12, 2011 | Samsung A501 Cellular Phone
Does not turn on
If your nuvi does not turn on, then you need to check the battery and the charger. Try another battery that is well charged in your gps receiver to see if it will work. If another battery works on your gps, then it means your battery is either weak or bad. To confirm if your battery is weak or bad, fix it in another gps receiver and charge for about 2 hours to see if it will power ion your gps, if it does, then you know your charger is bad and has not been charging the battery.
Also test the charger by trying to use it to charge another gps to see if it will charge, if it does, then the charger is okay but if it does not,then it is obvious that the charger is bad. And the solution to that is for you to replace the charger.
Also check the charging port on your gps and the port where you connect the charger on the car, if the two seem to be working when tested on another device.
That should do the job for you.
Dec 24, 2010 | Garmin nuvi 205W GPS Receiver
There is a yellow light flashing and battery not charging. I bought a second hand battery charger and it doesn't seem to be working either as there are no lights lighting up. Is there any way of testing...
the charger has three out points the one on the left at the side combined with the point at the back should be putting out 14 volts if not the charger is dead as for the battery the pack needs to be pulled apart and a test done on them that needs a tech with the proper equipment
hope this helps please remember to rate me
Nov 28, 2010 | Panasonic EY6409NQKW 12 - Volt Drill/...
Phones won't charge
hi,
have tested the charger if it is working?
if you test the charger with another phone and is working perfectly then the charging port of your phone is bad.
the charging port is the port where you insert the charger.
try and get a new charging port and replace with the bad one, the phone will charge.
thanks for using fixya.
Jun 06, 2010 | Panasonic KX-T7885 Cordless Phone
Test charger ey 0110
TAKE TEST METER ON DC VOLTAGE AND PLACE ON THE TERMINAL IN CHARGER SHOULD READ 12 VOLTS ON 2 OF THE TERMINALS IF YOU DON'T HAVE A METER YOU CAN USE A TAIL LAMP SOCKET AND BULB OR ANY DC LAMP OF A 12 VOLT RATING
Nov 26, 2008 | Panasonic EY6409NQKW 12 - Volt Drill/...
Just purchased a panasonic dmc tz5 and charged the battery and camera wont work.
What do you mean 'won't work'. Won't power on?
If it won't power on and camera and battery is new. I would suspect batterry or charger fault to begin with, assuming you know the outlet socket you charged it in is good. Charger should have green light on while charging batt for about 3 hours.
If you have a voltmeter, outside terminals of charged battery should read about 3.7 to 4Volts. Also be sure battery is installed correctly. Don't belive it can be reversed, but not sure.
Hope this helps.
May 16, 2008 | Panasonic Cameras
Won't turn on
possible problems: 1) battery charger is bad and isn't actually charging the battery. Test by charging on another charger if possible. 2) batteries are bad and are not actually recharging. test by using other batteries if possible. 3) batteries are not making contact properly inside the camera. Test by cleaning connections of the batteries and the camera. See if orienting the camera one way or another will allow it to turn on. Generally fiddle with it. 4) other, unknown, internal camera problem. Contact Panasonic service.
Dec 26, 2005 | Panasonic Lumix DMC-LC43 Digital Camera
Panasonic EY6409NQKW 12 - Volt Drill/ Driver Kit Logo
872 people viewed this question
Top Panasonic Drills Experts
Craig Butler
Craig Butler
Joseph A Howard
Level 1 Expert
Tom Chichester
Are you a Panasonic Drill Expert? Answer questions, earn points and help others
