Question about Toshiba Satellite A135-S2276 Notebook
Dvd rom wont open or turn on
Tecra 8100 got wet wouldnt start for a daynow it only starts off of power cord not battery and the dvd rom wont open
any suggestions
  • Daniel Florin
    Daniel Florin May 11, 2010
    You should Levit to Dry out more than a Day.
  • 741 Answers
Get yourself a paper clip. Straighten it out. There is a small hole on the DVD ROM drive. Stick the straight end of the paperclip in the hole and it will click a release button and your DVD ROM door will slide out.
Don't forget to rate this with 4 stars before you log out.
Posted on Jan 29, 2009
No power on my leptop
Pull out the battery, wait for 10 mins then replug the battery and check for power lights. check whether your power charger is in working condition. if it's under warranty rush to your nearest service center. most probably it's motherboard is faulty.
Nov 11, 2013 | Toshiba 14.1" Tecra 8100 Pt810u-00953...
Computer will not start
may be the lithium battery ,needs changing ,or needs new main battery also check the connection as sometimes it becomes loose and needs repair , I ant me expert but I sorted my computer this way hope it helped ,,also give all internal a good clean. hope this helps .
Nov 18, 2012 | Toshiba Tecra 8100 Notebook
It is a toshiba tecra 8100 note book i plug it in and it just wont turn on. at all.
Do you get any lights? Does it show if the battery is charging at all? Try plugging it in without the battery.
You also may have a bad powercord or loose jack inside the computer where it plugs in. See if you jiggle it where it plugs in if any lights come on to indicate it has power or is charging the battery.
Oct 17, 2010 | Toshiba Satellite A60 Notebook
Powers on wont post but dvd rom
Eject any disk from the DVD device.
Turn the computer off.
Disconnect the "data" and/or the "power" connectors from the DVD-ROM.
Turn the computer on, and see if it starts when the DVD-ROM is not part of your system.
If it starts, then your DVD-ROM needs to be replaced.
Dec 08, 2009 | Medion Computers & Internet
P4M800 Wont boot
Hello there:
please try this first unplug the power to the computer
next open the case and unplug all of the cables and cords that connect to the harddrive cd rom ect ect
now locate the power supply cord that goes to the motherboard and disconnect
press the power button on the computer for 20 seconds and also if you have a reset button press it . what this hoes is releases any stored esd that is in the computer ..
now plug in the power supply back into the board and plug in the power cord and try to boot the computer and see if it comes on if so great just plug in the cords to the cd rom harddrive ect ect and than reboot and you should be ok
Sep 23, 2009 | Biostar P4M800-M7A Motherboard
I have a Toshiba Tecra 8100, and it won't start up. A few months ago, my charger for it broke since it was so old and dilapidated. I recently purchased a brand new replacement charger and hooked it up, but...
Try to replace the battery or take it out all together. but first check to make sure that the chager is the right one. Make sure it is one of these. you can use this site to get an idea if you have the right one.
Sep 05, 2009 | Toshiba Tecra 8100 Notebook
Tecra 8100
The battery is rechargeable, you should have received an AC adapter when you purchased the laptop.
Please rate, Thanks!
Feb 27, 2009 | Toshiba Tecra 8100 Notebook
Hi my laptop wouldn't start up so I bought a new battery and it still wont start up. I can get the power light and the battery light so I don't think it's the power cord I can pull out battery adn unplucg...
Reseat the RAM.
Sometimes the RAM needs reseating because the RAM module/s are not making proper electrical contact with the motherboard.
If this doesn't work then :-
The RAM module/s could be faulty, if you have two RAM modules, remove the both modules and insert one at a time and bootup you computer to test them to determine the faulty RAM module.
Feb 19, 2009 | Toshiba Tecra 8100 Notebook
Toshiba Tecra 8100 PC Notebook
if it can boot up windows, then the harddisk is not locked(anymore, after entering the correct password),
a slow performance of windows can be sped up by performing a harddisk defragmentation (open windows explorer, right-click onto harddisk, switch to properties,´then 'extras', perform a defragmentation for drive c:, give it time to finish)
to fix the arkward dvd/usb prob:
again open up win explorer and see if cd-rom drive is available, therefore recognized by windows at all.. if yes test-insert Original CD again, see if it can open it(does the CD/DVD-drive LED flash green several times and do you hear any noise from it?)
if not, shut down and enter BIOS while booting hitting either the Del,F1 or F2 button and look if under IDE devices the CD-is recognized by the laptop itself...
if not, set auto detecton for IDE- devices, go
through available menus until u find USB legacy support, enable as well, exit saving changes, reboot.
Again enter BIOS then change
BOOT DEVICE order sothat CD-drive is 1st,
any 3.5'' floppy drive second and harddisk 2nd or 3rd, exit saving changes again.
reboot and let windows come up again. check for cd/dvd-drive again(see procedure as described above), check if windows does recognize your usb-device(mp3 player) now.
if that does not work and during booting you get message'bad CMOS checksum error' you will have replace the CMOS button-battery on
the mainboard, for it may have gone flat...
this means disassembling the laptop
if that is the case, see a technician to work for you or come again with another query.
hope i could be of help
Oct 20, 2008 | Toshiba Tecra 8100 Notebook
Tecra 8100
remove the battery, run it on ac power pack, for five min, then install battery while it's on.
Apr 18, 2008 | Toshiba Tecra 8100 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
