1.Carefully push the SIM card out of the wallet-sized plastic card carrier.
2.Turn your Huawei M835 off.
3.Grasp the notch at the top of the back panel and pull away from the Huawei M835 to remove the back cover.
4.You'll see a notch at the top of the battery.Use it to lift the battery out of the Huawei M835.
5. Your SIM card has one corner missing.Slide the SIM card into the SIM slot so that the corners match.Ensure that the gold contacts are facing downwards.You will hear a click.
6. Reinstall the battery and back cover and then power up the Huawei M835
Rooting ...allows you to make bianary changes to your phone you wouldn't normally have access to for your phones protection. You can change your fonts, and many other core settings. Befor making any changes be sure to make a backup of all your phones settings and core bianary's using a good backup program so you can resort back to these or reinstall a core program if there's a problem. Be carefull to the changes that you make because : you can render you phone unusable or it can get stuck in "bootloop". This will make your phone useless! Be sure to read up on all modifications before attempting to do this. A good website to do this is xda.developers.com
This How To UNbrick your huawei m835 phone step by step. To tell if your phone is bricked it should only show just the huawei logo or the android logo when you try turn it on and no key combination works to boot into recovery, if u can boot into recovery, dont use this guide.
1) Click This Link to download Huaweis Oringinal Software. ---->HUAWEI M835 - Huawei Device Co., Ltd.. a)Click on the software tab and select the first file there. It may or may not show an error but dont worry just refresh the page and the download will start. 2)When its done, open the M860V100R001C153B251SP03 folder (the folder you just downloaded).You should see another folder called dload and some instructions.If you dont understand what im saying then click the instructions in the folder.
3)Connect your SD card NOT your m835 phone into the computer.
4)Then drag the dload folder any were on the SD card.
5)When thats done take out your battery and put it back in.
6)Press and hold Volume Up + End Call + And The power button at the same time.(i know this sounds wrong but it works)
7)Its Gonna Update your firmware.
8)When its done Turn On your device and the screen that popped up when you first got your phone should appear.
9)Continue with that and BAM your phone is now UNbricked.
Try calling either #228 or i think its *228 and re-programming your phone, it will change the lock code to its default, he last 4 digits of your number without changing anything else
To remove battery from Huawei m835, Turn the back of the phone, remove the outer covering(casing), put your hand in the space provided to lift the battery and the battery is out.
