Question about Panasonic EY6409NQKW 12 - Volt Drill/ Driver Kit
Test charger ey 0110
How can I test the panasonic ey 0110 charger to see if it is working properly.
I know my batteries are no longer any good; but I want to determine if my charger is faulty
  • 359 Answers
Posted on Nov 27, 2008
My RCA tablet won't turn on and will not charge, what can I do?
If battery is depleted, then no, it will not turn on.
If battery charger is dead, phone won't charge or turn on.
If battery charger cable is broken, tablet won't charge or turn on.
You need to ensure you have a good working charger, and a good cable. Only a known good charger and a known good cable can charge the unit. Borrow or invest in a new charger and cable (they're cheap on eBay).
Only once you know the charger and cable are good can you determine that they are not the problem.
Depending on how old the unit is, it's possible the battery can no longer hold a charge and needs to be replaced. You won't know that though until you first determine the charger and cable you're using are working properly and providing a good charge.
May 07, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
Battery not holding charge or charger not charger
I am sorry to hear that your battery or charger are no longer working. I would suggest locating your local service center to have your charger and battery tested. Depending on the age of your unit, the battery may have reached the end of its life. Our service center would be able to determine exactly which is not working properly and determine warranty status. Please follow the link below to locate your nearest service center.
Thank You
Black + Decker Customer Care
blackanddecker com
Feb 27, 2015 | Black & Decker CHV1510 Vacuum
My tablet won't turn on or change
Check to make sure that your charger is working. Test with voltmeter for proper voltage. If charger is working teh battery may no longer work.
Sep 14, 2014 | Tablets & eReaders
Impact driver
IF ......It, s an older model Panasonic EY with carbon brushes the armature (motor) and brushes allways both parts must be replaced for a longer lasting repair in that case but don,t forget to inspect the state of the wires and 2 mosfets that are placed on a separate heatsink below the switch look at that part either , if the tool is older then 4 years and you trust the switch no longer when in doubt do not repair. it, the marketing and warranty on Panasonic are now in better conditions . ask your dealer
Jan 02, 2014 | Panasonic Drills
There is a yellow light flashing and battery not charging. I bought a second hand battery charger and it doesn't seem to be working either as there are no lights lighting up. Is there any way of testing...
the charger has three out points the one on the left at the side combined with the point at the back should be putting out 14 volts if not the charger is dead as for the battery the pack needs to be pulled apart and a test done on them that needs a tech with the proper equipment
hope this helps please remember to rate me
Nov 28, 2010 | Panasonic EY6409NQKW 12 - Volt Drill/...
The battery charger in the trasfer case is not charging the battery
have you tested the battery to see if its a good one? if its a dud it wont charge up, and whet tests have you done to see if it realy is not charging the battery, the times iv had this,,, its not charging,,, when it was, but the battery was a dud,
however check all the fuses and trips and put an avo meeter set to amps x10 in line with the battery after you have started the charget to see if it realy is not charging up,,, if its not look at the rectifier,,it may have a blown diodes in it
Nov 05, 2009 | Watts Onan Portable Generator - 5000 ,...
When I put my battery in the charger is flashes red.
Hi Olivia. Thanks for your reply.
When the charger flashes red, it means that either:
A) you battery terminals are dirty, or, it's not put in the charger properly.
B) You have a bad battery.
I'm going to assume that you're putting it in the charger correctly because you have had it a long time and know how to properly insert it. The battery terminals being dirty are highly unlikely.
So this is my opinion:
The fact that your battery is a year and half old tells me right away that your battery is a gonner. Your charger flashing red tells me that it can no longer flow current to the battery. I'm sorry, but you need to purchase a new battery. Good news is that they aren't too expensive, approximately $20 usd, and you can find one on the web very easily.
Make sure you get the right battery. Whichever one you buy, make sure it fits your camera. I do know that it's a 3.7 volt np-20 battery. You want to purchase one with a high mAh number. The mAh number relates to how long it will run your camera between chargings. The higher the number, the longer it should run your camera.
Also, note, in the future, don't charge your battery for longer than 2 hours at a time. It should only take 90 minutes to fully charge it. If you charge it longer than that, it will get too hot and dramatically shorten the life of your battery!
Sorry I didn't have good news, but I wanted to make sure you were properly armed with knowledge.
Thanks for coming to FixYa. Come back if you have any other questions, and remember to rate my solution a fixya.
Mar 13, 2009 | Casio Exilim EX-Z120 Digital Camera
Panasonic EY0110 Charger
Use a volt meter attatch to the contacts and see if you are getting 12 volts .If so then your charger should be okay
Nov 26, 2008 | Panasonic EY6409NQKW 12 - Volt Drill/...
Panasonic PV-DV100 Mini DV...
Try to find same battery charger or camera and do Cross-Check, hook new charger with camera and confirm charging process and hook your charger in other same camera and confirm is it working? You will rectify the problem unit, either camera or charger.
Aug 17, 2008 | Panasonic PV-DV100 Mini DV Digital...
Won't turn on
possible problems: 1) battery charger is bad and isn't actually charging the battery. Test by charging on another charger if possible. 2) batteries are bad and are not actually recharging. test by using other batteries if possible. 3) batteries are not making contact properly inside the camera. Test by cleaning connections of the batteries and the camera. See if orienting the camera one way or another will allow it to turn on. Generally fiddle with it. 4) other, unknown, internal camera problem. Contact Panasonic service.
Dec 26, 2005 | Panasonic Lumix DMC-LC43 Digital Camera
Panasonic EY6409NQKW 12 - Volt Drill/ Driver Kit Logo
446 people viewed this question
Top Panasonic Drills Experts
Craig Butler
Craig Butler
Joseph A Howard
Level 1 Expert
Are you a Panasonic Drill Expert? Answer questions, earn points and help others
