Question about AT&T 1717 Digital Answering Machine
Need to change the date and time - AT&T 1717 Digital Answering Machine
  • 71 Answers
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press "Play/Stop" to exit
Setting the Clock at any time.
1 Press and hold "Clock" until the
Message Window displays C, and the
default day is announced.
2 To change the day setting, hold down
"Memo/Repeat" or "ANNC/SKIP" until the
correct day is announced. Then
release the button.
3 Press and release "Clock". The current
hour setting is announced.
4 To change the hour setting, hold down
"Memo/Repeat"or "ANNC/SKIP" until the
correct hour is announced. Then
release the button.
5 Press and release "CLOCK". The current
minutes setting is announced.
6 To change the minutes setting, hold
down "Memo/Repeat" or "ANNC/SKIP" until the
correct minutes setting is announced.
Then release the button.
7 Press and release "CLOCK". The new day
and time are announced.
To check the clock, press and release
"Clock".
Posted on Jan 21, 2009
Change the date and time
Good day!
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
Mar 28, 2014 | Computers & Internet
Need to change time on my toshiba laptop pc
Windows 7 and below:
Start> Control Panel> Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Windows 8: Start> Type control and control panel will pop-up on the search list, click on that to open control panel>Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Feb 07, 2014 | Toshiba Computers & Internet
Date change
Click on time section of your start bar (bottom right of screen). Then choose adjust time and date settings.. Following on screen setups to change it over to correct date and time..
Jan 06, 2014 | Acer Computers & Internet
DATE -TIME RESET??
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings.
Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
David
Jun 10, 2013 | HP Compaq Presario V2000 Notebook
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Can't find my manual and need to reset the date and time
if system DK series must set at port "00"
#402 to check the port number with displayed phone
#651 DDMMYY - for date
#652 HHMMSS - for time
#653 to change the day
Apr 08, 2009 | Toshiba DKT3010SD Corded Phone
Change time & date on the victor 1530-5 adding machine
I recently solved this issue with my calculator
Press and hold the time key when the date is dispalyed. When the display flashes enter the date as a six digit date (example 110608 for November 6, 2008) Time needs to be entered in military time when changing time.
Aug 15, 2008 | Office Equipment & Supplies
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Cant change time on phone
time & date
Your phone needs the time and date for the datebook.
To synchronize the time and date with the network:
Press - > Settings > Initial Setup > Time and Date > Autoupdate
> On
To set the time and date: Press - > Settings > Initial Setup
> Time and Date > time or date.
To choose an analog or digital clock for your home screen,
press - > Settings > Personalize > Home Screen > Clock > Analog or
Digital.
hope this helps
riz.
Nov 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
CHANGE THE TIME/DATE AND TURN THE RINGER ON
You have to use the feature 9 # from the administrators phone (usually extension 100)
Go to extension 100, press "feature,9,#" and you'll see the numbers on your display blinking like a digital alarm clock. Enter the time and then press feature to complete.
Oct 11, 2007 | NEC DTU 8D-2 Corded Phone
AT&T 1717 Digital Answering Machine Logo
265 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
