Question about OKI Electric Industry B4545 Laser Printer
I have no instructions on how to set up paper feeds to printer.
OKI Microline 3390. paper just keeps running in and then putting itself offline. Instruction manual on setting up paper feeds would be most helpful. No correct settting seem to be in it for invoies and payslips.
Thank you
dodgecharger
  • 254 Answers
SOURCE: Setting Oki3320 page feed
Try Okidata's online site http://my.okidata.com/home.nsf/solutions%26support?openframeset I didn't see that specific model, but a similiar model should setup the same.
Posted on Aug 09, 2007
SOURCE: oki printer 3320 micromline
change to letter
Posted on Feb 22, 2008
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Posted on May 23, 2008
  • 8 Answers
SOURCE: oki microline 280
Check printer setup where you define carrige return and line feed options. Alot of times you need to set printer to do an auto CR on reciept of LF or auto LF on reciept of CR. I run into this all the time.
Posted on Sep 26, 2008
  • 8 Answers
SOURCE: oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Oki microline 320 form feed
Am afraid the Power Surge (when the power came back on) has damaged the unit and there is no "Reset" to these printers. You would need to replace the control board but as its a power surge there is a reasonable chance that the power supply will have been damaged/weakened and this will lead to a shortened life span of the printer. I would throw it away and replace with new. sorry, ( I am not a salesman either)
Jul 18, 2017 | OKI MICROLINE 321 Turbo Matrix Printer
Documents wont feed
If not using track feed paper this printer should have a setting for paper height. If its set too high the
rollers wont grab the paper. Also look for any paper that might be jammed or caught up in any of
the roller mechanics.
May 09, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Paper needs to be a little lower when it prints, it;s printing too high
hi,press the offline button , manually turn the paper feed knob back a few clicks then press the set button and remember to switch the printer mode to online
hope this helps
Apr 28, 2010 | OKI MICROLINE 390 Turbo Matrix Printer
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Constant jamming recently
Could be 2 things..
First Check close and make sure there are not small bits of paper in the feeding arms rollers etc.. any place paper passes make 100% sure. Second adjust the tension from the feeding arm and make sure the paper path to the printer is clear.
You can also hit it with a few shots of Dustoff
Jun 17, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki ML395 printer, paper continues to feed
your paper feed sensor maybe stuck or a piece of paper could be stuck in the sensor.Hope this helps ?
Dezzi
Nov 19, 2008 | OKI MICROLINE 395 Matrix Printer
Oki Microline 320 turbo alarm light
First, make sure that paper feed switch is set accordingly to the paper path you are using (rear feed, bottom feed or friction). If you make a change, turn the unit off and on.
If it is set correctly, there might be an obstruction on the printer top cover that interferes with the cover sensors. This forces the printer to think that the lid is still open and will signal it as you have described.
The last option will be a damage to the sensors or to the mainboard. This is rare, but if the case, you need a repair center.
Be blessed.
Nov 07, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
Aug 27, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Oki microline 280
Aug 02, 2008 | OKI MICROLINE 280 Elite Matrix Printer
OKI MICROLINE 591
You need to set and store paper size, width etc in printers internal menu and on print driver on pc.
See Oki manual for printer settings its written on the front of the machine i think menu and set power on, then print to see settings then read manual...
Jan 04, 2008 | OKI MICROLINE 591 Matrix Printer
OKI Electric Industry B4545 Laser Printer Logo
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
