Question about Philips 32PT6441/37 32" TV
Hi I have A philips model # 50pf7220a/37 50" plasma And When it is pluged in The green light flsahes red in a 7 blink cycle. I have narrowed the problem down to the ysus board. I was churious If anyone knew what component an the board may have gon bad? Or if anyone had a repair manual for these boards? The pcb# is lh14-03217a
    Habit-Forming:
    New Friend:
  • 55 Answers
If it's a PCB replace it if it isn't too expensive. Better yet get a LED screen TV and be done with it!
Posted on Aug 21, 2017
ttech
  • 139 Answers
SOURCE: Red screen Philips 28PW322/11
Does the Set Flash Bright red or Just a Dim Red
Posted on Jul 19, 2007
  • 48 Answers
SOURCE: Philips TV
Please PM me privately to tell you how to fix this problem... it's a bit lengthy.
Posted on Feb 23, 2008
SOURCE: Tv Won't come on green light blinks
All we had to do was unplug the TV and turn it back on after about 10 seconds. See if that works for you.
Posted on Jul 24, 2008
  • 116 Answers
SOURCE: philips 50" plasma ysus board troubles
Check for shorts, blown fuses on ysus, if blown replace entire board, easier than locating many of the parts installed on the board.
Posted on Dec 11, 2008
  • 44 Answers
SOURCE: 7 red blinking lights on tv
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
Philips 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help thanks
philips2_bing.gif 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help
Apr 26, 2010 | Philips Televison & Video
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
I have a 42" philips plasma with 8 red blinks
90% of the time this is capacitor related in the power supply, Remove the back and check for capacitors that are domed shaped on top, Replace these and all should be ok.
Mar 05, 2010 | Dell W2600 26 in. LCD Television
Plasma Philips 50
Ur power board have burn capcitors,like puff up or burst open,must changes these capacitors.Know how to solders?Tries Shopjimmy.com,Ebay.com for buying reburbish power board.
Jan 11, 2010 | Philips 50PF7220A Television
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philips 50" plasma ysus board troubles
Nov 26, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 32PT6441/37 32" TV Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
